First LS build
Old Aug 7, 2016 | 04:40 PM
madsv1000's Avatar
Default First LS build
Was coming from a party on the 4th of July and the engine started to knock as I was turning on the highway. Lucked up being only 2 miles from the house, but the damage was already done. So I'm starting on the fun task of rebuilding the engine. Had a set of heads ported waiting to be changed with a cam replacement. No better time than now to change them.
Old Aug 7, 2016 | 04:42 PM
HCI2000SS's Avatar
So what's the plan exactly?
Old Aug 7, 2016 | 04:46 PM
madsv1000's Avatar
Just a bit better than stock to be a tame/fun daily driver.
Old Aug 7, 2016 | 04:49 PM
HCI2000SS's Avatar
Good deal
Old Aug 7, 2016 | 05:08 PM
madsv1000's Avatar
Had four spun rod bearings. The blackened rod pictured was the worst of the set.
Old Aug 7, 2016 | 06:11 PM
madsv1000's Avatar
But I'm getting a little bit ahead of myself. I ended up removing the engine from the bottom, and I have to say it wasn't all that bad. I should have done it when I was driving third gens. Didn't really have any problems other than the hydraulic clutch "quick" disconnect. I tried everything and I have a cousin that is a GM servic tech. I was still stumped, and ended up just unbolting the master. Ten minutes vs. the 3 hours I spent trying to disconnect it. That thing gets the middle finger.
Old Aug 7, 2016 | 07:08 PM
brandon619's Avatar
Yeah those connections are a pain, there is a U shaped tool that helps depress the clearish/white collar.
Old Aug 7, 2016 | 07:38 PM
madsv1000's Avatar
Yeah I tried a couple of different ones to no avail.
Old Aug 7, 2016 | 07:41 PM
madsv1000's Avatar
Here is the time lapse of the removal. I had already disconnected everything other than the k member bolts at this point.
Old Aug 7, 2016 | 07:58 PM
madsv1000's Avatar
And I had some heads ported ready for a swap later, but this is as good a time as any. Had a set of 241 heads ported by head flow research. And made some impressive numbers.
Old Aug 7, 2016 | 08:21 PM
madsv1000's Avatar
Did a trunnion bearing upgrade yesterday.
Old Aug 8, 2016 | 04:05 PM
madsv1000's Avatar
Got my spring kit in today. I will post up photos of assembly and vac testing.
Old Aug 9, 2016 | 03:46 PM
madsv1000's Avatar
Springs and valves installed. Stock size ferrea vavles are what went into the heads.
Old Aug 11, 2016 | 08:50 AM
ss454327's Avatar
Those are some impressive flow numbers for 241s. That will be a sleeper at the track for sure. Intake from .300 to .600 and exhaust from .400 to .600 are outstanding!
Old Aug 12, 2016 | 07:58 AM
madsv1000's Avatar
Yeah, that's what I'm hoping for anyways.
Old Aug 12, 2016 | 06:56 PM
madsv1000's Avatar
Hoping to have my Pistons ordered here in the next few. The plan for Saturday is to degrease all the covers.
Old Aug 15, 2016 | 05:13 PM
madsv1000's Avatar
Got my Pistons ordered today, and got a freaking smoking deal on a set of mahle pistons.
Old Aug 17, 2016 | 09:12 AM
madsv1000's Avatar
Always nice having stuff delivered to work. Always brightens your day.
Old Aug 20, 2016 | 02:05 PM
madsv1000's Avatar
Dropped the block off at the machine shop to get cleaned this morning, and only 80 bucks. If I can get away with just that much in the machine shop I'll be ecstatic.
Old Aug 20, 2016 | 02:28 PM
Tuskyz28's Avatar
Looking good!! What cam you plan on running ?
