First LS build
Old Aug 31, 2017 | 11:27 AM
  #41
madsv1000's Avatar
Measured the bearing end on my rod set. All were within a tenth. Doing wrist pin bores after work.
Update: did the wrist pin bores and there was only 2-3 tenths of clearance. So I'm going to hone them out to 9 tenths to get the right oil clearance.
Old Sep 2, 2017 | 09:17 AM
  #42
madsv1000's Avatar
A little more done still have the middle and bottoms of the bores to measure.
Old Sep 2, 2017 | 10:13 AM
  #43
KCS's Avatar
KCS
Moderator
Good to see this thing being built properly. Piston pin clearance is often overlooked and finding only .0002-.0003" clearance in your rods should be a lesson to those who don't check.
Old Sep 2, 2017 | 10:35 AM
  #44
madsv1000's Avatar
Yeah, that's what our engine builders preach. Easy to blame a part failure when you didn't measure anything, and just hope the manufacturer got it right.
Old Sep 3, 2017 | 02:44 PM
  #45
madsv1000's Avatar
Finished the cylinder bores today they actually look really good for the mileage. Got the mains put back on going to measure those on Tuesday. Did a quick check of them seemed to be within spec.
Old Sep 5, 2017 | 11:18 AM
  #46
omc8's Avatar
And I had some heads ported ready for a swap later, but this is as good a time as any. Had a set of 241 heads ported by head flow research. And made some impressive numbers.
Just curious about those heads , they have a cnc program run on them correct ? I'm not sure who Head flow research is , they weren't done by AFR were they. Can you post up pics of the bowls runners and chamber work done .
Old Sep 5, 2017 | 03:07 PM
  #47
madsv1000's Avatar
No they were hand ported by a guy I work with. That's the name of his side Business. I have some pictures. I'll get better ones in the morning. Didn't really do any work to bowls.
Old Sep 6, 2017 | 03:08 PM
  #48
madsv1000's Avatar
Check the oil clearance on the rods today. They were a little on the big side. So I'm going to order a few sets of 1 under bearings to pull them back into spec.
Old Sep 7, 2017 | 11:39 AM
  #49
omc8's Avatar
Thanks for posting the pictures , I look forward to seeing the best pictures you have on those . I sent you a pm.
Old Sep 7, 2017 | 03:15 PM
  #50
madsv1000's Avatar
These are about the best I could get with my phone.
Old Sep 10, 2017 | 12:07 PM
  #51
madsv1000's Avatar
I ended up buying a new crank versus the old one being turned down or buying bearings. For the few bucks more of buying the new crank it is well worth the peace of mind.
Old Sep 15, 2017 | 01:10 PM
  #52
madsv1000's Avatar
Crank is at the machine shop getting the reloctor ring installed. Going into the shop Sunday to hone out the bores for the new pistons. Can't wait to start doing pre-assembly. Finally start feeling like I'm moving forward with the build after buying all these parts.
Old Sep 17, 2017 | 02:48 PM
  #53
madsv1000's Avatar
Got one cylinder bank most of the way done today! Have to do a final pass to knock down the peaks from the initial pass. Got the deck height measured too. Was with in half a thousands.
Old Sep 18, 2017 | 04:32 PM
  #54
madsv1000's Avatar
Final hone is done!! All the cylinders are within two tenths and cylinder tapper as well. Got to give a big shout out to my buddy Jonathan for doing the work. I just helped where I could during. Spent about two hours cleaning once he was done.
Old Sep 18, 2017 | 05:11 PM
  #55
Can't wait to see this come together!
Old Sep 19, 2017 | 07:52 AM
  #56
madsv1000's Avatar
You and me both.
Old Sep 19, 2017 | 11:21 AM
  #57
You and me both.
NO doubt! lol
Old Sep 19, 2017 | 03:12 PM
  #58
madsv1000's Avatar
*****! I was hoping to get away with not having to line hone the block, but I'm not so fortunate. Went through measuring the main bore housings and they were a little big. Changed the bolts since I was using the factory type TTA bolts thinking maybe they had streached. The measurements stayed the same.
Old Sep 22, 2017 | 03:06 PM
  #59
88stanger's Avatar
Awesome build!
I would scrub the floors and toilets to have access to that equipment!!!!!
Old Sep 23, 2017 | 10:01 AM
  #60
madsv1000's Avatar
Originally Posted by 88stanger
Awesome build!
Yeah, it's defiantly an advantage when you can walk up the hall and talk to an Engine builder. They build some pretty sweet stuff.
