New guy and New build.
I have 02 Trans am WS6, M6, 3.42 Rear end (will change once i get money)
bought a LM7 bored out to a 5.7L Short block from ATK Engines.
Block- 5.3l Iron block
Bore/Stroke- 3.903x 3.622
Crank- OE Reground 0.010/ 0.010
Rods- Scat Premium pro 4340 I-beam w/ ARP
Pistons- Wiseco 2618 Forged -3.2CC Flat top piston. Moly Skirt coated
Rings- Wiseco GFX (alloy steel top ring)
I Got TSP 225 As-Cast Heads with .660 dual springs 62CC
Cam- TSP TV4 231/234 .619/.612 111LSA
Rollmaster Single roller timing set
LS7 Lifters
7.450 Push rods from TSP (I will be checking length)
GM Performance Oil pump
ill be running stock intake/ injectors at first. I was going to go with a TSP mail order tune at first because me being stationed down here in Yuma AZ. theres like 0 performance shops that I know of that runs a dyno. nor any that i trust around here haha.
Exhaust
its a SLP loudmouth 2.
BBK longtube headers 2.5inch ORY pipe. (going Catless most likely.)
looking at a ls7 clutch and new steel flywheel.
one thing I'm kind of split is which head gasket to use. I was told with a GM .051 head gasket my compression ratio was going to be if I remember correctly it was 10.6.5. which I think that's a little low, which makes since sense i have the -3.2cc in the pistons but i didn't know it would effect it that bad? but once again this is my first build i have a lot of learning to do lol. but i was hoping to have higher compression. which if im trying to have a good DD that lays down good power. (my goal is right around 500 to the wheels.) which im sure im gonna fall short. but as long as its ball park obtainable with a intake/ injectors ill be really happy with my build.
If you have any questions please do ask.
and the engine can be worthless trashed,
and you lost nothing. Get another one.
The car becomes a "500 horsepower car" even when there is no engine installed (because any engine you install feeds off the turbo which never leaves the car)
As far as the #'s go....it really depends...and which numbers do you mean? E.T.? HP? Which HP...FWHP, RWHP? On what kind of Dyno? There's dozens and dozens of variables from weight of the car, to parts used, to competency of the tuner, to tire size, to the temperature outside, type of fuel ran...the list is rather long lol.
Your build list will put you in 430-450 territory as it stands right now. Thats rear tire.
You're going to need to step up to a fast102 intake and a compatible throttle. I'd also suggest you go with 1-7/8 headers into a 3" dual exhaust. Those changes will get you much closer to 500.
Then, if you plan to stick with LS7 lifters and clutch you're going to need more cam. Along the lines of 241/244. If you want to keep the cam moderate, then you'll need to budget for reduction of load to free up ponies, such as lighter clutch, electric water pump, manual steering or turn one pump.
Some things I'd recommend are upgraded rocker trunnions and 11/16 pushrods, or 3/8 if they will fit your heads. Also I didn't see a mention of an intake, gonna need a ported 102 or MSD to get towards your goals. 500 will take new exhaust, lifters, and clutch at a minimum.
ive heard the 3" exhaust isn't really a big gain between the 2.5. which I s why I went with the set up. I heard the only way you would benefit the 3" is at the higher RPMS?
and overall I did plan on running another intake but I'm not sure which one I wanna run with. I have a LS6 intake right now. but I know the 76MM TB and intake port is failing.
Building it how you want used to be respected now everyone jumps on the jy and boost it idea and look down on anything else.
Build what you want op. We have anything you need, parts, advice, tech info for anything you are looking for.
500 on a 5.7 with a moderate cam NA can be done but it's gotta be highly optimized to do it. Here's some examples - but I'm going to warn you that if you look at these all individual mods you'll say they don't do much. But when you add them up, it's how you get there.
Short travel lifters. You lose a lot less travel and response time between lifter and valve.
Larger diameter pushrods. Pushrods can be like pole-vaults. You need them NOT to flex.
Roller rockers. He stock type rocker has a progressive ratio. At low lift it's only 1.4-1.5. Roller tips stay a true 1.7 ratio at all lifts. Trunion upgrade won't fix this.
Electric water pump. Light clutch.
When I went from a 3"Y to a 3"dual it made a tremendous change to the car.
random thread:
Ebay turbos last too but you wont see me telling anyone to use them just like chinese head studs.
Welcome to the forum OP hope you brought popcorn! And a flame suit...
In lieu of this knowledge, lets take another look at junkyard engines produced between a specific era using the factory's detailed analysis in the past. In other words, we can predict an engine's future by comparing other engines produced in the same manner by the same factory, something you cannot do when it comes to a 1-off built engine. For example, Lets say 90% of all 5.3L engines from 2000 to 2002 are making it to 200,000 miles in work trucks with very little issue. Many of them may not be well maintained; sludge and muck abound, and yet here they are, still running. This gives you a much higher percentage chance (confidence) that the JY engine you select which appears to be in good condition is going to keep running for many miles (lets say you find one with 100k, well most of them hit 200k so that is 10~ years of driving 10k per year you can bet on with minimal risk, provided you do nothing to damage the engine) Now, the other side of the issue is the intended use: we must compare this high mileage statistic with the slew of individuals who have taken these 17~ year old junkyard engines and made double OEM horsepower reliably for 50,000+ additional miles and report little/no issues. After all, It doesn't do us any good if the motor can hit 200k unmodified, but when you double it's output suddenly it falls apart most of the time.
Thus the typical LSx of 2000~ fulfill these requirements: they are well known to achieve high mileage at double power output with minimal modifications. The risk is reduced significantly overall, regardless of cost, when an attempt is made. When you factor in the low cost as an added benefit- the JY engine becomes an obscenely obvious choice over anything 'built', due to the history/reliability vs cost at 'moderate' power level (often taken to be around double the OEM output, or approx 500-600 horsepower).
The machine work going into building a proper setup is key. Parts selection is second. The rest is all based off either budget or who is designing the build.
Stock parts can be pushed to limits, but i wont pretend they are the same limits as aftermarket.
