Recommend heads for my build!
What the car has as it sits today:
Stock bottom LS1
Torquer V2 cam
243 heads
ITB intake kit
ATI 10% UDP
1-7/8 Long Tubes with a 3.5" merge at the axle into a 4" single vibrant muffler
T56
Stock S2000 rear end (don't know how I haven't destroyed this yet)
Goals:
High compression (11.5ish:1 static)
450+ rwhp
Hurting as many feelings as possible.
Car is a street machine and is currently on 93 pump gas. May or may not go with E85 in the future depending on availability (which is very little in my area). I'm leaning towards the aftermarket and will sell the 243s once the new heads are on the car.
I know this has probably been discussed ad nauseum but my build is a wee bit different and there wasn't a lot of threads specific for the torquer V2.
Car made 387/388 with Hooker block huggers (1-5/8"). Hasn't been tuned on the Longtubes but hopefully they're good for 400+.
Here's a link to my dyno thread:
https://ls1tech.com/forums/dynamomet...irst-dyno.html
Either way if you want a build that drives well you could do something similar to mine. I had plenty of PTV clearance, but you may need a fast 92 or 102 set up to cross 450 rwhp. I didn't see that on your list.
After looking at your dyno chart it raised some questions. I know you have the ITB manifold(which is awesome) but I don't think it has much to do with what I noticed.
Your tq peak rpm is 3700. Then carry & start to drop at about 4700 rpm. Your hp peak rpm is about 5800. Carries great to 6500. Also your hp/tq numbers are so close. 387/388. These are just things I noticed. Even if the V2 cam was cut on the 114LSA that would give you 5 degrees of positive overlap. I would think the tq peak rpm would be higher & it make better hp, peak higher, up top. It seriously looks like the stock cam is still in there. Only saying this going off the dyno chart which could be all kinds of different on different dynos. Still.
Were you in your 1:1 gear when you were on the dyno?
Both heads have been proven time and time again to make amazing power for stock castings.
This...both are proven performers. I'm leaning toward AI when I have my 243s ported but I've personally seen TEAs work as well and it's top notch. If you just HAVE to spend more money the MMS heads are the way to go...
Stock bottom LS1
Torquer V2 cam
243 heads
ITB intake kit
ATI 10% UDP
T56
Goals:
450+ rwhp
lols2k,
We're currently running a special on all cathedral port head programs. $1050 shipped! New LSX dual spring kit with .660" and Ti retainers. Sale ends NEXT Friday the 21st.
If you have any questions, fire away! Love the build by the way.
-Russ
