Cost to install forged short block
Not including the cost of the shortblock and reusing everything possible off my current ls1 plus new gaskets and fasteners what could I expect to pay a shop in labor to do the swap? I'm willing to go with a different cam and better heads if my budget allows, but I'm looking to get an idea of bare minimum labor cost on swapping a forged short block in.
To build short block into a long block labor only $450 to $600.
Removing an old engine and installing a newly assembled long block. Labor is typically $1200 to $1800 for an engine swap. $1500 being pretty typical.
Install Procharger and tune $1000 to $2000 depending on who & where, guessing I have no idea bases on first hand experience.
About $3500 in labor at typical shop.
Here's my rough estimate... the motor estimates are in the ball park, I'm doing a build currently. I'm guessing on Procharger and didn't include items like radiator, fan, transmission upgrades, fuel system etc
Big power will at least need a new fuel pump suited to 600 hp, Racetronix $350 at least. Install $250 to $400 or free if you do it.
Forged short block probably $3500 to $5000 depending on whatlevel of quality parts you want in the engine.
Heads - low end $1,000 ( ported stock castings) to $3500 ( aftermarket) depending on the heads
Cam - $375 to $475 depending on if it's a shelf grind or custom
Intake & TB - LS1 stock $100, LS6 $400, Fast intake with NW TB $1200
Headers & Y pipe $250 used, $500 Speed Engineering, $1500 Kook's
Balancer stock $0, to $250 aftermarket to $475 for an ATI
Lifters, $100 LS7 to $1400 Isky Red top or Black Mamba's etc
Fuel injectors - say $400 could be less or more
Don't forget the boring stuff, water pump, gaskets, timing chain, push rods, oil pump, fluids, plugs, wires etc say $1000
Assembly of short block $450 to $750 depending on who and where.
Removing an old engine and installing a new engine labor is typically $1200 to $1800 with $1500 being pretty typical.
Procharger - I have no Idea $4500 used to $6500 new?
Install Procharger and tune $1000 to $2000 depending on who & where, guessing I have no idea.
Add 20% to cover stuff you will decide to add while doing project and to fix issues that always come up.
Junkyard 5.3 and eBay turbo is the cheap forced induction set from what I've read. The forced induction forum on this site can help with details.
In other words I would be showing up with a running car and a new short block they would have to go from there. I would expect that to be a lot of labor cost I'm just curious of a ball park figure so I can budget accordingly. Or they could build the current motor with forged rods and pistons with all arp fasteners. Again that would be a lot of labor costs. Just curious what a ball park figure would be.
Why go forged when the stock internals are good to 800ish HP??
Many times I see members do more harm than good going with a "forged motor". Finding a machine shop that can do a better job than GM at machining and final fitment is rare. Usually more harm than good is done in my experience. Not to mention the added down time and cost of having an aftermarket long/short block setup.
You can EASILY and reliably run 15lbs on ANY bone stock LS engine if it's tuned properly. Then figure a replacement bone stock long block will set you back $500-1000 and can be dropped in very quickly with no machine work if needed.
You don't even need to pull the heads off to run 15lbs. Install a mild cam and valve springs and bolt your blower on... 15lbs is nothing on E85 if setup properly.
8 seconds at 150+ isn’t done with the typical 15lb bolt-on blower kit. There are MANY ls1’s running over 15lbs reliably. There is no such thing as a reliable race car IMO. Somethings going to go wrong eventually, built motor or not. I’d rather replace bone stock SBE’s than “built” engines.
If the main goal is to run 15lbs on a blower, then being able to drop in another SBE quick an easy makes the choice a no brainer to me.
Personally I wouldn’t run anything smaller than the F1A either way. Depending on the RPM the smallest pulley setup should get you in a lowish boost range. They make restrictor plates that reduce the boost/performance on them if you want to start out at lower boost levels.
Unless you spend big bucks on the 347’s top end, you aren’t going to make 700whp on 15lbs with a blower. Best you can do is double the NA hp at the crank per 15-16lbs or so. With the amount of additional power required to turn a blower that number goes down. Then factor in drive train losses for WHP and it drops again. You’d need to have a VERY healthy NA motor to hit 700whp at 15lbs. It can be done, just not cost effective IMO. Making power with boost is cheap, esp. with a turbo.
Have you looked into a turbo? Makes 10x more sense looking at cost VS performance. But I get it’s not for everyone.
As an example of what an SBE can do look at this...
119 passes and most in the 7 second range at over 8k rpm. Now he has an SBE 4.8 in it.
https://ls1tech.com/forums/forced-in...l-going-3.html
Spend more of my budget on a better trans and driveline components and run the sbe as long as I can. Once it goes decide if I want to build a motor at that time or get a junk yard motor so I'm back in the game for a while. I got to admit that other than the down time I wouldn't feel any pain at all losing a sbe, but losing a $5000+ short block hurts I've been there before. That motor lasted 100+ passes NA plus daily driven for a year, then 100+ passes on a 150 shot, then a few passes on 200 before a bad tune melted a piston.
Honestly I know jack **** about turbos or tuning. That is why I wanted to go procharger. They make a nice kit for the GTO and it seems better for me and my goals. If I wanted 900+ rwhp it probably wouldn't be the best choice.
edit to add: Motor currently has just under 29,000 miles on it. I've owned it since the end of March. I put about 2000 miles on it. Most of that was driving home from near Chicago to pick it up then back and forth to Speed Inc to get the cam/converter install and tune. I did the rear suspension myself springs/adjustable shocks, sway bar, bushings, and 15" bogarts with drag radials.
You can pick up a $640 shipped S475 turbo and make a turbo kit pretty darn cheap. Or you can buy a kit that uses factory exhaust manifolds from someone likte these guys and it’s still cheaper than the average “bolt on” blower kit. Even with the stock cam you could make 600-700whp pretty easily on an ls1.
http://www.kbracing.net/about.html
His setup isn't respecting the body work(Has a couple fender cuts.. ) so the whole turbo setup comes out with the engine, except for the the turbo itself, Form a overall installation perspective the blower was a bout a wash vs the turbo the for installing, On both the intercooler piping is the painful part.
