Yella Terra rockers...anyone ever seen this...
Need some back ground. Were these in the car? How many miles and were they like that when installed? Did you install them and if so, did you install new pushrods and clean them with a pushrod brush first?
Are they pitted or only discolored? (Hard to tell because photo is blurry)
I would pull the rocker and pushrod on those and check the pushrod for blockage that may be restricting oil.
blowing air through pushrods the best way to check them?
Probably valve float or something. The axles in the roller tips appear to be walking out too. I would send pics to Yella Terra and see what they say. They may be able to rebuild them.
Try to find out more about your valvetrain too. Like what camshaft, what pushrods and what preload they have on the lifter, what springs and their open & closed pressures, and what installed and coilbind heights are for the springs.
It would be a good idea to see what lobes are on the cam and to pull lifters and look for lobe wear while things are apart.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
It has ls7 lifters and the rollers on them look really good. engines on the way to be rebuilt, will know cam condition when its pulled, lobes looked good from what I could see with it in motor
Be interesting to see what the rest of the valve train looks like.
either too weak of spring pressure, or too heavy of springs for the lifters and pushrods. Ls7 lifters aren't that great really. If the rocker is losing contact with the valve then the lifter can be losing contact with the cam. What happens then is the cam keeps coming around and slapping the lifter, resulting in damaged lifters and dents in the cam
