Thread chaser for main cap bolts.
Old Mar 3, 2018 | 10:04 AM
kossuth's Avatar
Default Thread chaser for main cap bolts.
Figured I would put this out after doing some serious looking. ARP makes a 10m x 2.00 thread chaser for LS main caps. Google searches never turn this up because apparently nobody advertises these things including Summit and Jegs. Talked to my local machine shop and he turned me onto where he got his because he had the same problem when studding out a race motor for a customer. Apparently they can only be found in ARPs paper catalog. The part number for the chase is 912-0014. And can be found on page 128 of their online catalog. http://arpcatalog.com/128/
Saw alot of threads on here where folks were looking for this thing and were having no luck as I was searching so here you go.
Old Mar 3, 2018 | 10:13 AM
How about CALLING ARP to confirm?
Old Mar 3, 2018 | 10:24 AM
kossuth's Avatar
I called yesterday and the tech gave the part number in question.
Old Mar 3, 2018 | 10:44 AM
pantera_efi's Avatar
Default Bottoming Taps
Hi ALL, I buy my Bottoming Taps FROM McMaster Carr.
I buy several at one time, a five pack.
I sell this item from time to time when I supply billet caps.
What kind of Machine Shop would NOT have this knowledge ?
Lance
Old Mar 3, 2018 | 11:09 AM
kossuth's Avatar
Lance
If you can get this from McMaster Carr please share the part number. I looked there directly and wasn’t able to find it.
Old Mar 3, 2018 | 04:09 PM
farmington's Avatar
A bottom tap IS NOT a thread chaser. A tap of any kind will remove some stock. A thread chaser will just clean existing threads
Old Mar 3, 2018 | 04:36 PM
This.
It’s a thread CLEANER, not a cutting tap. Basically removes dirt, oxidation, and makes it pretty.
Old Mar 6, 2018 | 05:42 PM
00pooterSS's Avatar
If you don't have a chaser take a stock bolt and slot it with a cutoff wheel and use that. That's what I do for long reach head bolts.
That's essentially all a chaser is anyway, a bolt with grooves cut in it for debris to collect in.
Old Mar 6, 2018 | 07:44 PM
KCS's Avatar
KCS
Moderator
I do the same. Works perfectly and is way cheaper lol
Old Mar 6, 2018 | 08:26 PM
00pooterSS's Avatar
Fk yeah. Hell I've even done it with spark plugs!
