Time for more power
I went to the pro vacuum pump with the 12 a.n line on gz motorsports recommendation. I am tired of leaks down back of motor.
I find there is a lot of data discrepancy out there on the SD's. You may need to do a LOT of interpolating in the offset table.
Will get it dialed in on 93 pump gas then convert to flex fuel. Not sure what to expect for gains but if it picks up 10+ hp and tq I guess its worth it
you did the right thing -- get them from someone who flow matched them and derived the data themselves. Did not mean to imply you'd be unhappy.
So I have a meth kit I intended on running even if just spraying water but now going e85 im not sure it's worth the trouble.
Added weight but still cools intake charge
I will wait to sell the kit and injectors until then as my 60s are perfectly tuned
Transmission will be back and installed with help from Lonnie Deirs (owner of extreme automatics) as a non lock up. Converter is sent to him straight from fti to be tested for fit and pump pressure together.
8" fti converter somewhere around a 5500 foot brake and who knows on trans brake.
Gzmotorsports super pro vacuum pump, now a mezier ls1 55 gpm electric water pump as well.
To be installed after Lonnie is happy with transmission performance and is gone.
Dont want to make any changes before as to not encounter troubles
I bought snake eater performance 80# sd injectors , ac delco ethanol content sensor to go flex fuel but will he last to be done.
These changes are all I had left in my want to do list until after I dyno through basani exhaust again and compare them to open 18" extensions. If gains dont justify losing thos exhaust sound then I'll stay as is.
If gains justify it I'll move this exhaust to my dodge ram truck and get 3" speed engineering dual exhaust.
This became way more expensive than I ever planned but it's the way I've wanted it for a long time. Only live once 😂
Electric water pump
Ict billet manual tensioner
Some goodies came in. Just going to wait until the transmission is back in and all working before I change anything.
transmission temps stay 160 ish unless I run it hard . then it goes back down pretty quick after fan kicks on.
engine temps are higher mostly because of dart iron block and raised the compression up. I will get it down even if I need a bigger radiator, and move my ram air kit out the way to see if its blocking off to much air flow. its the SLP aluminum ram air kit, may change that out anyway as the lid set up seems to be a restriction now .
