Time for more power
I'm thinking maybe a magnum with 2.97 first gear ratio to make clutches live longer. Any opinions on this ratio?
I went through 5 automatics in 3years and less than 5000total miles.
If I go 2.97 first gear it should take some load off the clutch to get moving and also wont skimp on a clutch. I want a durable clutch with an easy pedal feel.
My rst clutch I had last drove great but died the first pass down the track behind my 6.0 @ 452 rwhp
Since im going non lock up, I sent the converter back to the company I bought from and they are buying it back.
I am working with FTI on a 8" converter if they can do one as they have never built one for a 4l80.
I have fought oil leaks on this motor in the valve covers and valley cover. I have a new valley cover on the way since mine had a hole put in to use a pcv valve. That is coming out and I just made a call to GZ motorsports. After talking about my build he recommended his pro kit as im at the max for his sportsman kit. At first when I built this motor I was interested in a pump but the thought of spending that much extra was to scary.
After fighting oil leaks on a 8000 rpm motor, it's a no brainer. Plus he said I'd pick up good power from the style rings used.
So converter is gonna be more aggressive and now a vacuum pump. And ordered 80# injectors to go e85/flex fuel.Gonna get nasty😁
I hate oil leaks and even though j found my leak and it's a simple fix i decided to just do it. When i go back to tune the car on the dyno it will be done and not still wanting a few things for later .
After this ,its cosmetic stuff to be done
I went to the pro vacuum pump with the 12 a.n line on gz motorsports recommendation. I am tired of leaks down back of motor.
