Time for more power
Old Apr 27, 2019 | 12:47 PM
  #161
AINT SKEERED's Avatar
Originally Posted by big hammer
This car needs to gape nerds
This car has to do something besides sit in shop. Hopefully soon those gremlins are gone
Old May 3, 2019 | 10:49 AM
  #162
Finkledbody's Avatar
it'll be a pleasure to watch this thing shred the streets. Thanks for sharing your build!
Old May 3, 2019 | 11:35 AM
  #163
Darth_V8r's Avatar
Moderator
LOL at first I read that as -- shred the SHEETS -- and I was like wtf is he doing with his car???
Old May 3, 2019 | 05:24 PM
  #164
Thanks. The transmission just came back today and hopefully have it back in the car Monday. Busy weekend with family.
I've had more fun in the sheets this week.instead of working on car in the shop.thats got to count 😂
Old May 3, 2019 | 05:57 PM
  #165
Originally Posted by AINT SKEERED
I've had more fun in the sheets this week instead of working on car in the shop. That's got to count 😂
Oh it does..... it REALLY does! lol
Old May 3, 2019 | 08:29 PM
  #166
Today was first time in my shop since I got off the boat Tuesday. I started fooling around with hooking up the meth kit. Also instead of keeping the nitrous nozzle hidden, I'm going in opposite side of air kid from meth nozzle. It's a dry kit so a single nozzle is all it is.
Old May 10, 2019 | 08:10 PM
  #167
Transmission is back in as of Monday. Had to come back to work on the boat but will be going to get front end alignment next Thursday then putting miles on it
Old Jun 3, 2019 | 08:32 AM
  #168
I relocated the coils, got my front end alignment and all that is left im aware of is to change my valve covers to the new set since the valve covers leak at the spacers.
I bought the yella terra thick gasket to move the cover up so 8I shouldn't have to do much clearance work to the covers.
I bought off Ebay some baffled 10an fittings to put in the covers to go to the catch can, I will be going to machine shop to mock up the fittings on old heads he has to make sure baffles in good location.
I took my car on a nice ride last night for the first time since rebuilding the motor. It done well, felt strong the 1 time I hit it(couldn't help my self).
I am having a issue after start up i.didnt Have before air fuel reads 22/1 and it is spitting and backfiring. Wont accept throttle changes and wants to idle around 600 rpm when it should be 1050.
It had gotten to where it done it even cold and would not run .I flashed a previous tune back in and it's been fine. After that drive to a friends and it sat for an hour, I cranked it to leave and it acted up again for about 20 seconds and finally was able to give it throttle and clear it up.
Any one know what this may be?
Old Jun 3, 2019 | 08:45 AM
  #169
Darth_V8r's Avatar
Moderator
Speed density?
Old Jun 3, 2019 | 08:47 AM
  #170
Speed density?
Yes efi live cos5
Old Jun 3, 2019 | 08:53 AM
  #171
Darth_V8r's Avatar
Moderator
In your maf curve set the lowest cell to 20 g/sec. needs air until the maf fails. If you skip this step it will be a pain in the *** to start after a fresh write until the maf finally fails
Old Jun 3, 2019 | 09:03 AM
  #172
I had that at 15 from you showing me that previous. But that was also for the old 6.0
New motor needs 20?
Old Jun 3, 2019 | 09:07 AM
  #173
Darth_V8r's Avatar
Moderator
It might help cold start. I was assuming you had a super low value there. Your maf fails first error?
Old Jun 3, 2019 | 09:10 AM
  #174
It starts and runs fine after flashing. It's several start up later it will act up.
Old Jun 3, 2019 | 09:17 AM
  #175
I just checked my throttle body bolts and found they were looser than they should be.
Could have been getting air in from there so I'll try this to see what that does after tightening.
Old Jun 4, 2019 | 06:34 PM
  #176
Drove the car and it feels good. Drove good, still needed some tuning for part throttle but my lap top was dead.
Made one first and second gear hit, felt really good so I set up the dyno for next Wednesday at engine power systems . Will post those that evening
Old Jun 4, 2019 | 06:44 PM
  #177
JakeFusion's Avatar
Super Hulk Smash
Go Geoff @ EPS!
Old Jun 4, 2019 | 08:53 PM
  #178
Originally Posted by JakeFusion
Go Geoff @ EPS!
I've been going to Geoff for over 10 years. It's his cam in it as well. Knows his stuff
Old Jun 4, 2019 | 09:09 PM
  #179
JakeFusion's Avatar
Super Hulk Smash
When my new combo comes together (where the f are my heads?!) I'll street tune it and then probably take to him to get the number. And then I'll back it up by going to Huck's in Foley, AL for one of their dyno BBQ days for backup numbers.
Old Jun 4, 2019 | 09:51 PM
  #180
Where are you located?
Yeah I talked to gavin about the haymaker heads in the future. Certainly wont be pulling mine until I get a set in hand . Quote 4weeka took 12 to get the ported 823s
