steem vent, 2 or 4 port
My 5.3 liter truck motor from 1999 is a four port. GM made the decision that perhaps only two were needed for your engine. I don't believe this choice is up to us end users. It is what it is.
Rick
Rick
My LS1 came with the rear steam cross over ports plugged and so did all of the LS2's, 3's and 7's. I'm running it the same way with aftermarket LS7 style heads on an LSX block with the factory water pump, radiator, fans, etc. and haven't had any issues. When running a high performance engine on the street its not a good idea to be sitting in stopped traffic during the heat of summer with the air conditioner on for any extended period of time. Of course we can always improve on the cooling system such as electric pumps, larger radiators and fans and yes utilizing the four corner steam crossovers.
GM went to 2-port steam vents for building ease as the engines did fine on a PRODUCTION BASIS. The 4-port setup has an advantage for the car hobbyist (that would be "US") in that when filling the cooling system, it does a better job of bleeding all the air out.
It's not really about bleeding the air. It's more about getting more coolant out of the rear hotter cylinders.
I did a 4 corner coolant mod to a 8sec turbo ls camaro a few years ago for a guy. He was having head gasket issues and woukd run hot sometimes. I set his up with a surge tank. Ran all 4 corners individually to the tank then plumbed the return to the upper rad hose. Last time i talked to him is was fine and no more blown headgaskets.
Not sure about the truck motors, but when GM made the LS6 intake standard on the LS1s in '01, they switched to the 2 port steam vent. I thought it was for clearance issues under the manifold but my memory is getting foggy.
The heads aren't blocked, they just have plugs installed instead of a steam pipe.
Some have used truck crossovers on the rear. I plan on running HPDEs with my C5 so I added a factory front crosspver to the rear, if it were a street car I'd likely leave the stock rear block offs and the front crossover.
https://ls1tech.com/forums/generatio...line-help.html
https://www.corvetteforum.com/forums...eads-rear.html
The following users liked this post:
arwokc (08-14-2020)
I'm betting that the coolant temperature at the back of the heads are most likely the same whether your a 2 or a 4 port or whatever.
I said my bet is that the temperature will be no different. May be somebody can chime in and disprove my theory. If you want to add another crossover go ahead but I don't think your doing anything more than added another place for the coolant to go.
