Diagnosing low compression cylinder
Old May 24, 2019 | 09:01 PM
Tomas240SS's Avatar
Default Diagnosing low compression cylinder
Looking for some feedback. I have a lq9 with roughly 180psi in all cylinders except for cylinder #8 with 95psi cranking pressure.
Inconsistant leak down test results so far. Thinking I have a lifter or valve issue (Valve to left in video). Please see youtube Video.
Thanks
Old May 24, 2019 | 10:18 PM
dixiebandit69's Avatar
If that is indeed cylinder number 8, my recommendation is to loosen the rocker arms, then pressurize the cylinder. If it holds pressure well, then you're going to have to take the cylinder head off and find out what is wrong.
I hope that helps.
EDIT: Did you do this test with all of the spark plugs out?
Old May 24, 2019 | 10:29 PM
LLLosingit's Avatar
Was this test done cold or warm? Did squirting oil into the cylinder help pressure? A leak down test should help you locate the problem, The pressure has to going somewhere.
Old May 24, 2019 | 10:50 PM
Tomas240SS's Avatar
I hope that helps.
Good Idea, I will try again after loosening the rocker arms, just to avoid and possible pressure on valve. My hope is that its not a bent rod.
Thanks
Old May 24, 2019 | 10:54 PM
Tomas240SS's Avatar
This was done not cold but not operating temp (roughly 140 coolant temp). I didn't squirt oil into the cylinder either. I had about 4 percent leak down in that cylinder, which lead me to scratch my head after only getting 95psi compression reading.
Old May 24, 2019 | 11:35 PM
Darth_V8r's Avatar
Moderator
If compression comes up with oil squirt its rings. If not, its a valve or head gasket.
Old May 25, 2019 | 07:53 AM
Tomas240SS's Avatar
Thanks, going to give it another go this evening.
Old May 25, 2019 | 04:30 PM
RB04Av's Avatar
Try an air fitting and compressed air. Just see where the air goes.
It will either leak into the crankcase (rings), intake (int valve), or exhaust (exh valve). Any other possibilities are pretty remote.
My money would be on a valve, but you never know until you check.
 Michael S. Palmer
Old May 25, 2019 | 10:54 PM
LLLosingit's Avatar
That's what a leak down test does.
Old Jun 3, 2019 | 07:03 AM
Tomas240SS's Avatar
It was a bent exhuast valve, you can see in the video. The one on the left ticking and returning slowly to its seat. Problem was it would return to the seat and seal....and give me good leak down numbers but when cranking would be low compression numbers. Thanks the help guys, new heads already installed with upgrades.
