862 Head milling for compression.
Old Dec 28, 2019 | 07:20 AM
ShawnK's Avatar
Default 862 Head milling for compression.
Looking to increase the compression on my 5.3 gen 3 (lm7) engine that has 862 heads on it. Hoping to find the right amount of head milling and head gasket to get up to a compression ratio that will run on 91 octane. Also doing a small cam upgrade 212/218 but I’m sure the PTV will be fine since It’s minor modifications (pistons are dished).
Thanks for any input!
Old Dec 28, 2019 | 09:16 AM
wannafbody's Avatar
For that small of a cam I wouldn't bother with milling the heads. The 862 are the smallest chamber factory LS heads made. The heads you have will work with 87, 89, 91 or 93 octane.
Old Dec 28, 2019 | 12:29 PM
I see OP's point. The LM7 only has 9.5:1 compression. A .040 gasket might get him up to 9.72:1.
About .020 off the head besides the gasket mentioned will get him to just over 10:1
Old Dec 28, 2019 | 02:32 PM
wannafbody's Avatar
I didn't realize compression was that low on the LM7.
Old Dec 29, 2019 | 12:03 AM
1FastBrick's Avatar
862/706 with a factory 61cc chamber and a .051 thickness is 9.5:1. changing to .040 gasket will put you at .9.72:1
.025 will take you from 61CC down to 58CC. If you were at 9.5:1 stock it would put you at 9.83:1 milled.
If you went to a .040 head gasket in addition to milled heads then it would be about 10.08:1
Which 212/218 cam are you going to run?
Old Dec 29, 2019 | 12:34 AM
1FastBrick found my source! LOL!! Fun to play with..
Which number do you use for milling 862/706's? I thought .006 per 1cc reduction, coming up with about .020" for 3cc, but it looks like you use about .008/1cc to get .025" for a 3cc reduction.
I guess that could be different depending on the model of head.
Old Dec 29, 2019 | 12:38 AM
1FastBrick's Avatar
Its not a true number as each shape is different.
I just had some 706 heads done and they came out to 58cc with a .025 mill. I measured the stock castings around 61cc
Old Dec 29, 2019 | 12:49 AM
1FastBrick's Avatar
As I mentioned size and shape of the chamber plays a role.
These are 706 stage 2 heads that where done by Richard at WCCH earlier this year.
Old Dec 29, 2019 | 12:01 PM
Thank you! Richard knows his stuff, especially lately with the 706/862 truck heads! Then I shall consider your numbers golden...
It appears .025 will get 706 heads down to 58cc instead of the .020 I mentioned. The smaller the chamber, the more cut per cc...
Old Dec 29, 2019 | 01:59 PM
SoCalDave's Avatar
If your budjet allows have your 862 heads ported before you put them back on. A bump in compression and improved flow should do you well.
Old Jan 13, 2020 | 05:14 PM
ShawnK's Avatar
Default more milling more head gasket
Is it possible to run a stock head gasket and mill the heads for .035 instead of .025 and still gain the 10:1 (ish) compression? (Thinner head gasket is very expensive) Also hoping to run Skip to the beginning of the images gallery
Stage 2 Thumpr 226/237 Hydraulic Roller Cam for GEN III LS 5.3 ls
will that still have safe PVC?
Old Jan 13, 2020 | 05:54 PM
LilJayV10's Avatar
Thinner head gasket increases the quench which allows you to run higher compression with out detonation.
win, win
Old Jan 14, 2020 | 12:40 AM
64post's Avatar
Measure the chamber before and after you mill it, not all 862s are 61cc, (61.5) they can be as much as 63cc. I have run 11.6:1 static on 91 with 26* of total timing with less than .040” quench without detonation or timing retard.
Old Jan 14, 2020 | 12:53 AM
That's better than I thought! How much compression could a guy get away with running 87 or 88 with a small (200-210 degrees intake at .050) cam?
Old Jan 14, 2020 | 05:35 PM
cookseyb's Avatar
Send the heads to (862-706) to Texas Speed and tell them what you need ,Awsom Results!!
Old Jan 14, 2020 | 08:41 PM
patSS/00's Avatar
What cam?
Old Jan 15, 2020 | 10:54 PM
64post's Avatar
CamMotion Titan 4, 227-232@.050 113, 3.5* of overlap
Old Jan 16, 2020 | 11:04 AM
patSS/00's Avatar
That puts you about 8.5 dynamic compression (using 11.6 static). Nice to have a real world example for running that high compression on 91.
