ls1 oil pump same thru what years? engines?
The ls1 346 oil pump is the same as the 4.8-6.0 engines and is the oil pump the same as the later 08 tahoe hybrid 6.0? From 97 forward how long did they use the ls1 346 oil pump and on what engines and when did it change over to a newer style pump? ls2 ls3?
All Gen III and IV pumps interchange.
The only different ones were for AFM/DOD and VVT which are higher volume for those applications only, and the variable displacement one used in hybrid drivetrains.
Otherwise all the std. volume pumps are the same.
The LS3 uses the standard volume pump. There is no specific LS1 oil pump.
Any of the standard volume pumps should be fine, as they are about identical to Gen III pumps, BUT the higher volume or variable displacement pumps might not.
They also used the Melling 10295(maybe the 10296, I was half asleep when I watched it) I think it had a little over 100psi
The stock style pump was 70ish psi.
It was really interesting to see the power difference between the three pumps.
The following users liked this post:
G Atsma (10-28-2022)
Yeah, the DOD/AFM pumps have higher volume. So is the Melling 10296.
Stock style pumps are the same for both Gen III and IV.
Oil pressure is dictated by, and is a measurement of resistance, which is bearing clearances. You could effectively get whatever number you desire with a stiff enough bypass spring, very tight bearing clearances, and an oil that stays viscous at temp. And of course enough pump to push volume, which most LS pumps will do with ease.
A stock replacement Gen III Melling M295 pump will flow enough oil to do most anything you'd want to do with a wet sump engine. By the time the high volume pump is actually needed, you're likely ready (and better off) to go dry sump anyway.
The results of the EM episode are about inline with what I've seen as well.
G Atsma (10-29-2022)
Hello, im new to the ls1 forums, im currently doing a mild build on my 2002 ls1 and a local machine shop guy told me to use an oil pump from a 2008 chevy tahoe 6.2 melling part #M365. im reading here that that isnt a good idea?
Read this thread. The stock-size pump is very adequate for most relatively stock LS engines
Stock is fine. The Melling 10296, which I run due to piston oil squirters, is a good oil pump, especially if you leave the standard relief valve spring in it. But stock is fine for just about any build except DOD, piston oilers, etc.....
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
G Atsma (12-19-2022)
