Cam for stock heads
Old 08-23-2004, 10:43 PM
Z-286speed's Avatar
Default Cam for stock heads
Which cam would you guys recommend for stock heads. I have TSP true duals, pacesetter LTs, lid and a pro 5.0 with the z06 clutch kit. I want a large lope.
Old 08-23-2004, 11:28 PM
glennhl's Avatar
TSP 224R 112LSA. 224/224/.581/.581/112LSA. Mine doesn't have any advance ground in. Makes good power and depending where you set the idle it lopes. I have it at 925 and it sound stock until I open the electric cutout. Good power from 6000 to 6500.
Old 08-23-2004, 11:32 PM
CamaroCain's Avatar
TSP Magic Stick v3, do a search in here and in the dyno forum, i believe it fits the stock heads without having to flycut.
Old 08-23-2004, 11:35 PM
HavATampa's Avatar
While you're looking at TSP, ask about the 225/225 .589/.589 /112. They claim 390+ hp on stock heads. I will be installing mine in about a month.
Old 08-23-2004, 11:41 PM
Unusual T/A's Avatar
G5X2 dyno numbers in sig.
Specs 232/240 .595/.609 112LSA
Old 08-23-2004, 11:45 PM
LSUxBlake's Avatar
FMS F11 228/230 .581/.591 112LSA . VERY streetable, several people are making well over 400rwhp on this cam alone.
Old 08-24-2004, 12:41 AM
jrp
SN95 Director
jrp's Avatar
everyone is just gonna recommend the cam that they have, what i suggest you do is more research and find the one that suites you. w/o knowing your intended application recommendations are pretty irrelevant.
Old 08-24-2004, 04:49 AM
Z-286speed's Avatar
I have searched many cams, and just want to hear what all people get out of there cams. I really am looking into the magic stick and the 231/237. I want extreme power and one hell of a lope.
Old 08-24-2004, 06:23 AM
jrp
SN95 Director
jrp's Avatar
hows this lope sound to you?
Old 08-24-2004, 09:34 AM
cyphur's Avatar
well the magic stick will offer you higher numbers then the 231/237 for sure, no doubt about that. will also be rougher driving around town, and i don't know what your plans are for this car, but a 231/237 will put you right around 400rwhp cam-only. magick stick will get you quite a bit higher obviously, but down the road when you go to get heads, you'll be VERY restricted, as if you plan on getting anything other then stock height you'll be flycutting. for what its worth the 231/237 has a hell of a lope, and loves the spray. very strong cam, lays down great numbers. its the cam i have sittin in my room waitin on some complimenting parts to be installed. my car is a daily driver and wanted to avoid the bucking under 2k rpms that ppl with cams like TReX have. Thats just my .02.
Old 08-24-2004, 10:50 AM
CamaroCain's Avatar
the new MS v3 that was just introduced should be a litte more friendly then the v1 that I run, and I drive mine around no problems, its all in the tuning. Also, what is the big deal about flycutting?? Is it just something people dont want to do because they can't do it themselves in their own garage???
Old 08-24-2004, 10:51 AM
PREDATOR-Z's Avatar
Also check the X1 from MTI> 231/227,.591/.571 112lsa
or the new G1 228/232, .588/.575 113lsa
Old 08-24-2004, 06:05 PM
Z-286speed's Avatar
Ya, i have read a lot about the 231/237 and live in lubbock where tsp is located and talked to them about it. You know all people are bias on there cams they make so i wanted other peoples input on it.
Old 08-24-2004, 06:08 PM
Z-286speed's Avatar
The sound tract did not load. I am planning on getting heads down the road and want to install them. Flycutting is not a huge deal for me, just not the biggest fan. But if the tune and power is there, i do not see a problem doing it.
Old 08-24-2004, 10:08 PM
CamaroCain's Avatar
Well then tell Jason and Trevor that Lynda Cain says you should run the new MS v3 cam, sounds perfect for you goals
Old 08-24-2004, 10:14 PM
ta_silver_bullet's Avatar
yeha im just running a comp xe-r 224/224 .581/.581 114 and its runs really well. i will get soem track times this friday
Old 08-24-2004, 11:22 PM
FASTONE's Avatar
That TSP 231\237 sure is popular right now!
Old 08-25-2004, 11:01 AM
Lostpatrolman's Avatar
wow jrp, that cam is crazy. It sounds meaner then the track only cars. What cam is that?
Old 08-25-2004, 08:54 PM
LS1SS4ever's Avatar
Thumbs up
Sounds great
Old 08-25-2004, 10:31 PM
cyphur's Avatar
actually lynda i have nothing against flycutting, i'm just not building this motor into a max-effort. i also realize that drivability is often found in the tune these days. however, right now my main focus has to be college, unfortunately and not my baby if i could work 65 hours a week to pay for her in all her glory, i most definitely would right now she upgrades in stages....
