Lower Oil Pressure? Forged Motor bearing specs vs. stock?
Is it normal to see a bit lower oil pressure readings from a forged motor vs. stock? Is it true they have a bit looser tolerances than stock, flow more oil but show less pressure?
Am seeing a bit lower oil pressure than my old motor. Did change to a lighter oil temporarily and also have a new Vortech sucking oil out of the pump now too.
Thx!
Thx!
Not sure. It's an MTI motor.
I normally run 10W40 here in hot Florida, but have 5W30 in there temporarily since we used dealer Mobil1 oil. Will be changing it shortly. I'm used to the pressure readings with 10W40 RedLine.
Anyone know MTI bearing specs?
Any thoughts on the Vortech oiling system effect on oil pressure?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by MyLS1Hauls
Vortechs just mist the oil into the supercharger, therefore it uses very little volume. I'll be the lower pressures are related to the main bearing tolerances. STD replacement Federal Moguls will give you more clearance than a stock STD bearing. Some places use a +.001" bearing to tighten the clearances back up. The only way to know the actual specs is if MTI recorded it (they should have) or take it apart and measure it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
What are the benefits of looser bearings?
Looser clearances allow for less friction thus increased HP gained by negating possible frictional losses.
Is lower pressure always bad?
It depends on how low it is at hot idle and at high RPM driving.
Does looser have higher flow?
Holding all things constant let's look at this. If we make the clearances looser we increase the potential space between the bearing and journal(s). This potential space is filled by the oil that is pumped through the journals via the oil pump. The oil pump can only pump as much oil that can be pulled into the pump and pushed out of it. So, unless you alter the oil pump to increase its volume then you really can't increase the volume of the oil being pumped in a closed system such as this (engine).
Am currently seeing 20psi Hot at idle.
Is making me paranoid.
Need to call MTI to check their bearing clearance specs.
May replace the stock oil pump for peace of mind this week.
How long should an oil pump swap take with the motor in the car? Any major headaches involved?
With a vette, I think the major PITA is the steering rack. It's gotta come out.
jMX has instructions on oil pump swap on his site at http://www.ls1howto.com - his 'vette heads/cam instructions show the oil pump.
