Broken valve spring! Question?
Old Oct 3, 2004 | 02:50 PM
Whitey's Avatar
Default Broken valve spring! Question?
I had a post a week or so ago about random misfire code and a miss I couldn't figure out. After changing plugs/plug wires swapping coil packs, I finally found a broken valve spring.
My question is the spring blew almost a full coil right out of the middle of the spring. Most of the time I see the springs snap on the top or bottom coils. Is there a reason for this?
Old Oct 3, 2004 | 02:55 PM
cyphur's Avatar
How many miles on the springs? What kind of miles were they, ie how many passes, were they city or highway miles...or did you romp on it everywhere. If you tormented your valvesprings, then having a more violent failure is a little more understandable.
Old Oct 3, 2004 | 03:07 PM
Whitey's Avatar
The springs are dual springs and they had about 6000 miles on them. The car had a few dozen runs at the track and the rest of the time is fairly easy street miles. The cam is the .561 lift TR224.
Old Oct 3, 2004 | 11:08 PM
ss2668's Avatar
i just recently broke a valve spring in my car. 99 ss with 65k completly stock. car had a real bad misfire, didnt knock or tick or anything. the spring came out in 3 pieces.
Old Oct 3, 2004 | 11:20 PM
V8er's Avatar
Was the spring you broke a Patriot Gold dual? Broken in 6k miles with a .561 lift cam? Please fill in the details, this doesn't sound very comforting!
Old Oct 4, 2004 | 07:28 AM
Whitey's Avatar
No it wasn't one of the new springs. I bought one of the first set of Patriot heads two years ago. Mine came with the bad valves that Patriot replaced with new ones. I haven't contacted Patriot yet to see if they will work something out with me. I really don't beat my car up so I was really surprised when I found the spring broke.
The reason I posted this question is because I wondered with the spring breaking this way if this was common.
Old Oct 4, 2004 | 07:41 AM
Viper's Avatar
My ISKY295D broke into 3 pieces, and the retainer and keepers were no where near the valve that dropped. FWIW.
Old Oct 4, 2004 | 07:50 AM
Whitey's Avatar
Guess its not that uncommon, the price of going fast!!
