Any 228/232 cams out there?
Its a 228 on XE-R lobe (.588) and 232 on an XE lobe (.575) on a 114. I coulnd't find anything by searching but I did find that MTI just came out with the G1 which is very close to what I am interested in. I wasn't considering the 113 LSA they have it on but maybe it would work. Still couln't find anything however. I am looking to hit 400hp with nice drivability and idle manners. Don't want to do spring changes every 10K either. Any input?
sometimes cheaper then they get sold.a tr 224 is recommeded to change the springs at 15k intervals... i had like 25 on mine and never had a problem though heh.
I was actually thinking about a FM11 or FM13 before this and I don't know why I leaned away from them but I think I saw more numbers below then above 400. Maybe giving FM a call might help. I've always been kinda patial to Comp lobe profiles though. I just cant decide and its making me crazy! I am ultimately trying to set up for H/C with the AFR 225s but also cant decide whether to do a cam first or the whole H/C swap. Ugggg! I want to do all the work myself and have a week at Thanksgiving and about 2 during Xmas off which makes for perfect car time.
Did you actually check the spring pressure or just do a visual to deam them OK?
Money is not really the problem, neither is paying for a professional install, BUT I want to learn, do it myself and have that satisfaction. If I want to pursue a H/C soon, I don't want to just throw on the heads with a cam. I will have to consider how much to mill, hand finishing, intake port matched and flowed with the heads, P to V clearence and possibly flycutting the pistons (beyond me - don't think I can do that) . Alot of stuff to do just to get the right combo.
Sorry about getting off track sooo Anyone have this cam or something close TR230?
THanks
it was a comp grind....228/232 .568/.568 on a 112 lsa
My set up was in a '98 Z28...that cam, CNC'ed 6 liter heads, ls6 intake, hooker long tubes/orp and a cutout after the y-pipe, magna flow muffler,spec 3 clutch, and tuning. My computer kept giving me issues kicking the car into low octane tables, and pulling like 10 degrees timing, but anyways, it put down 432/418.
I bought the setup used from a friend...He didnt have the pcm issues i had and "supposivly" put down 448hp and 431Tq...."supposivly."
I loved that cam...sounded mean as hell and had a hell of a top pull to it. Screamed from 3200 to 6600-6800 where ever i shifted at...Made power up there also.
I just recommended it to a someone else that was looking for some nice power.
hope that helped.
-Chris
I'll be more than happy to e-mail you some dyno graphs from various installations we've completed and answer any questions you might have.
The G1 comes standard on a 113 LSA, but it is also available on a 112, 114 and 115 depending on your preference!
Thanks and best regards,
David Coates
MTI
Houston, TX
David Coates
MTI
Houston, TX
David Coates
MTI
Houston, TX
Nice numbers....hopefully that put you arouond 410hp, estimating a conservative 5 rwhp for each. What were you numbers before the cam? I'm hoping to get 40 hp out of it. If not, I will go with something bigger.
