Texas Speed 402 (LS2 & LQ9) Short Blocks
We are proud to now offer several different short block packages for our LS-1 customers!
These stroker kits feature:
Mahle Coated Forged Pistons 4.005" Bore
Mahle 1.5mm,1.5mm,3mm Rings
Forged H Beam 6.125 Rods
4340 Forged Stroker Crankshaft
New GM Engine Block
Clevite H Series Rod & Main Bearings
GM Camshaft Bearings
Complete Engine Balance & Assembly With Detailed Clearance Specs
Capable of supporting 600+ Horsepower!!
Iron Block Short Block
$3500*
Aluminum Block (LS2) Short Block
$4099*
*prices does not include shipping & crating fees
Jason
Texas Speed
www.texas-speed.com
806.866.0734
New GM Engine Block
$3500*
$4099*
Jason
Texas Speed
www.texas-speed.com
806.866.0734
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
LSxGuy widda 9sec Mustang
Sorry for the delay guys! It's eagle forged parts.
This is a intro special on the short blocks!
It will be about 10.5:1 compression with cometic gaskets & 67cc heads.
The Mahle pistons are -12cc
Shipping depends on the location
Originally Posted by Mas280
Are the ARP main bolts needed for this motor?
Connecting rods usually have 'made by ARP' bolts installed. The only other ARP bolt available in a shortblock would be the main cap bolts/studs. Those can be added as an option, but we havn't seen a need unless your after crazy power levels.
Originally Posted by 69_YENKO
*& how long is this price good for?
What about getting a lower compression version?? Maybe a 9:1 instead?
