Well, it finally happened... a lifter fell during a cam swap.
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by 2001 Pewter WS6
That sucks... Got to drop the pan and pull a head...
Gomer.... it's a bitch. Really. Psych up. Drop the pan from the rear, leaving the front cover bolts in, but threaded out as far as possible. "Should" be able to get a teloscopic mirror in there far enough to locate it. Then the teloscoping pen magnet. I used the bendable kind to make it go where I wanted it to go.
Took about three hours worth of fishing, but got it.
Good luck, keep 'hydrated' during the mission.... it helps.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Damn, I didnt know it could fall in the pan, but I know you had to pull the head if it dropped. If your going to do that, might as well do the head and cam package. Unless it's the drivers side head, less is attached to it so it's easier to get off. And you thought it was going to another fun day. Be strong, one out of how many that you've done!
![Gruffy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_gruffy.gif)
UPDATE: Ok, I went back out there and looked at everything. I got good news and bad news. Good news is that it is only the passengers side, so I only have to pull one head, no big deal. Bad news is that FOUR of those SOB's fell. The back four on the passenger side. That leads me to belive there is something wrong with the plastic retainer that is supposed to hold them. It's not my car, it's a local guy here that I'm doing a cam swap for. I'm going to pull the pan first and see if I can get the MFing lifters out, then I'll pull that head. It's 8:30pm here now, I'll report back in about 2 or 3 hours.... gotta make a run to the beer store first, this looks like it may require atleast a half a case.
Restricted User
Originally Posted by gomer
That's what I was thinking. Can you get the pan down low enough without hitting the Kmember?
Pull the motor mount bolts and raise the motor. Slide the on top of the lower mounts and lower the engine down on top of the bolts. This will hole the motor up a couple inches. You may want to pull the intake for extra clearance from under the cowl. The pan will come all the way off this way. Good luck...
Restricted User
How are you raising the engine? With a cherry picker? Mine is up at the shop and I'm doing this one in my garage. Could I put a floor jack on the front of the bellhousing and raise it up high enough that way? This is a M6 car, so I wouldn't have to worry about caving in the pan on it. Right now I have all the bolts out of the pan, but that SOB won't move but about an 1/8 of an inch. I' going to go pull the motormount bolts right now.
Best of luck Gomer. When I was doing my cam swaps I was always fearing that in the back of my mind. Lotsa damn work for something so small. I even had pen magnets I bought at Autozone in the pushrod holes!!!
doh!!!
Yeah, I will never again change the cam without something holding up the lifters. I got lucky but the weird thing was how the lifters wouldnt stay up after the new cam was installed.
UPDATE: Bad news is that FOUR of those SOB's fell. The back four on the passenger side. That leads me to belive there is something wrong with the plastic retainer that is supposed to hold them.
