rough idle after tune?
Alright guys I decided on the F13 w/114 lsa with the intentions on lowering my idle in order it to be "lopey". Is this safe to do, and does it effect power and performance in anyway? Allen highly suggested the 114 lsa on the A4 so any input would be helpful, I just want a deep rougher idle?
Thanks
Thanks
What size converter/gears do you have? If you really want a rough idle I don't see why you couldn't go 112 LSA. I'm running the MS3 on my auto and it's really not bad.
Thanks
Thanks
For now I have 3.23 gears - and im not lookn to change real soon does anyone have a similar set-up? With a lopey idle?
My best 60' before the cam was 1.726 with a 1.742 on my best run(12.62). After the cam and dyno tune, no other changes by best 60' was 1.739 with a 1.79 on my best run (12.21). I was not able to stick as well the day with the cam as I was previously either. This is with a cam a bit larger than the F13, whose power doesn't start for real till 4k. As you can see, my best 60' was only 0.013 slower.
Of course, I made more power and went quicker/faster but my 60' didn't improve, which is what should really happen. I'm having the converter restalled from 3500 to 4000 this month, that should help a good bit. I will move to 3.73's eventually as well. Possibly as early as this fall.
