New 408 shortblock; oil problems
Double & triple checked O-Ring connection. Re-used same o-ring but appears to be in good shape. Pick-up tube to oil pump connection is solid and seated flush. Used old ported oil pump then swapped in new LS6 pump. Installed autometer oil pressure gauge to confirm dash gauge. Low pressure continues.
1) Saw a recent post about a rear oil plug. Did not take notice of plug before install. Have email to engine builder, waiting for response.
2) Someone has posted that 10psi/1000rpm is suffucient. Seems very low to me. I am in that range but shouldn't be getting warning lights if it is ok.
3) If motor was built to "race" tolerances, which may mean larger bearing clearances, what kind of pressure range is normal? Still think what I am getting is exceptionally low.
4) How to remedy problem w/ distant engine builder. I can't take vehicle to engine builder for inspection/confirmation. Recommendations?
At this point I've done all I can think of. I re-isntalled the oil system. Double check connections and torque requirements. Confirmed gauge readings. Using 10-30 dino oil.
Any thoughts?
Thanks for any and all help...
Doesnt pass the common sense test.
Just because it "looks good" doesnt mean it is. It could be nicked, it could be distorted from age/heat.
I will paypal you the nickel and the dollars worth of gas to go get a new oring if you are that tight
RSX - No arguement from me. As soon as we had the problem we were wishing we had one gotten a replacement ahead of time. Can be assured that I will be at the parts department to day picking up a few. I really hope it is as simple as the o-ring. I'll know the answer later today. Thanks.
Mike K. - Exactly. Got the block from a sponsor and waiting to hear from them. Just wondering how others have dealt with the situation. Thanks.
Appreciate the help...
Need to secure the buddies for the tranny drop first. Will check the oil as described and let you know. Thanks again.
Thanks to everyone for their ideas and concern appreciate it.
My shortblock install checklist is as follows:
1) new oil pump O-Ring
2) rear oil galley plug
3) crank shaft key (stock one may not fit exactly)
4) new gaskets and seals for all pans
5) new crankshaft bolt (or ARP version)
6) re-threading kit (for cleaning-up threads on bolts, nut & bosses)
