Comp 218/224 .527/.534 114 vs. Hotcam
I have been looking at the Hotcam (I know many people here despise that cam) but don't want anything too big. I also want to keep things reasonable so I don't have to deal with spring changes. Comp has a similar cam as the hotcam and it might have a better idle and possibly be better on emissions. Wondering if anyone has experience with both or can provide some feedback on the comparison of these two cams. I am looking for streetable torque with some upper end so peak HP is not my goal here.
Originally Posted by Unaffiliated Racing
You will have to change the springs on ANY Comp Cam. They are way more agressive than that old outdated hotcam. Will stock springs work?...sure. The question is...For how long?
Thanks,
Brian
Thanks,
Brian
I've been looking at the Crane 216/224 .551/.551, mainly because of 1500 min rpm. I've also been looking at the Comp Cams XR265HR (212/218 .538/.563 115). How do these compare in power curve to something like SLP's 220/220 .5??/.5??; what's the reason for equal duration vs longer exhaust duration for power? Also, given two cams of equal duration and lift, what does a lower or higher LSA do to the power curve? Is it the lower LSA, the rougher the idle and higher the power curve shifts?
Here's what I have so far: 2K LS1 w/stock cam and heads, SLP cai & lid, 85mm MAF, 160stat, SLP hf cats and LTs, Loudmouth, and SLP Predator tune. The dyno (Mustang) run with mods but before tune was 308 MP @ 5250/324 MT @ 4500; after the tune it ran 335 MP @ 5500/345 MT @ 4750 (so if you're debating whether to get a tuner, the Predator was well worth it). The power curve seems noticeably higher, but there's still plenty of torque if I give it a little more partial throttle than before. At WOT is screams, and pulls strong all the way to red line, in fact it really starts cranking at about 3-4 grand. It just keeps going and going and going... I can't wait to get it to the track. OK, If I choose a cam because of the lower min rpm (say 1500) given that the power curve has already bumped up, am I being dumb and mis-matching the cam and tune? Might it be that with the LTs and Loudmouth, that I'm missing some back pressure; I do have high flow cats after the headers... How will the car respond to the new cam given the Predator tune? I want it to still be streetable, but I have the M6, so that makes it a lot easier.
Thanks... obviously I've been reading a lot lately, but need help putting it together...
I Got The Xr265hr Cam And You Can Barely Hear It And I Hate It. I Wish I Would Have Gotten A Bigger Cam. I Just Like To Hear It. It Performs Pretty Good. Also Still Have Stock Springs. Over 10000 Miles.
Originally Posted by Brian@CompCams
Your right..that is pretty good. I wasn't trying to put the hotcam down. It's outdated in the sense that it was the very first cam available for the LS-1 and now there is a lot more technology available for the LS-1. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
