Degreeing the Camshaft Attention engine builders
Supose I could jets get a way and installing the cam "straightUp".
Any info would be great, what should I do???????
Chris
But yes it was installe before but no in my engine.
Is is not a good practice to degree all cams for correct installation? After a bit of research I think I might be able to send the serial number off of this cam to Lingenfelter for a new cam card.
Chris
Chris
Install it "dot to dot" and then check the opening and closing events at .050 - the results will confirm duration -
Next, check lobe centerlines and you can tell what would be "straight up" LSA and whether or not the cam is ground advanced or retarded.
Charlie
Chris
The use of a degree is when installing a "custom cam", like a CamMotion or similiar and you want to be damn sure it was ground as ordered. Also, if the cam is installed with advance, say 4 degrees. the card and degree kit are used to check that yes, the cam was installed with a proper advance.
Lingenfelter has a good rep and their cam is most likely ground as advertised. Knowing it was used sucessfully before all but confirms that. So, unless you're installing the cam advanced or retarded, lining it up dot to dot should suffice.
Hope this helps.
Schantin
2002 Camaro Z28 M6
Too many folks seem to trust that if you install it, and it doesn't bang a piston, its right. That too often is not the case, and many folks just mistakenly believe that "dot to dot" is close enough. If you have the means and the ability to check the cam, then I advise everyone to check the cam when installing it no matter what the grind is.
Chris
Degreeing a cam is not to make sure it's ground right, but to make sure it's installed right. The QC at most cam grinders is done to make sure they are ground correctly, installing the cam correctly is the key. As I have said before "Dot to Dot is comparable to wearing Depends when you should just learn to hold it."
If you don't agree with me on this need to degree a camshaft, well good luck to you but the first time you bend a set of valves and have to tear down the motor to replace them and then degree the cam in properly you will understand.... luckily I always degree in cams so I don't have to learn this lesson.
Bret
Bret
Preach On my friend.
Degreeing a cam is not to make sure it's ground right, but to make sure it's installed right. [/i]
Bret
A tool like a Cam Dr is used to check lobe profile accuratcy and to make sure that the lobes on a V8 pushrod motor are at the right LSA... the ICL only depends on where you place it in the motor. Hence that's how you check if it's GROUND correctly (cams are done on a cam grinder so they are ground)
When you install a cam you put the cam in, the belt, gear or timing chain on and check to make sure the ICL and/or ECL are correct. A cam can be ground correctly but if the cam is installed incorrectly it really doesn't matter how accurate the cam is manufactured. You can install them correctly or incorrectly, only way to tell is with a degree wheel.
Bret
every cam designed for an ls1 (if ground correctly) is meant to be installed dot to dot...or at least that i have seen. if i have a cam that is ground correctly (to spec) and is meant to be installed dot to dot, is there any way it can be installed incorrectly if it is in fact installed dot to dot? with a stock timing chain there is a lot of "play" in the chain and the teeth on the cam gear are pretty damn big, so it is obvious if it isn't installed dot to dot. i don't see how a small adjustment could be made even using the stock chain...
if a cam is designed to be installed straight up dot to dot and is ground correctly to spec, please explain to me how it can be installed incorrectly...
maybe if i saw someone degree a cam i would understand it better...thanks
