Edelbrock/Lingenfelter LS1 Head Images
The following information is a preview of things to come from Edelbrock and Lingenfelter on the LS1 Cylinder Head. They will initially be offered in three configurations, the Pro-Port casting [#61989] for professional CNC porting; the complete Edelbrock/Lingenfelter CNC ported head [#61969] and the CNC ported head bare, without parts [#61979]:
61989: Edelbrock Pro-Port LS1 Casting for professional CNC porting
![](http://www.edelbrock.com/advertising/web_images/LS1%20Heads/images/61989.jpg)
![](http://www.edelbrock.com/advertising/web_images/LS1%20Heads/images/61989exh.jpg)
61989 LS1 Pro-Port Features include:
-Machined to OE dimensions to allow for an easy transition with existing CNC programs
-Tall intake short turn and small intake cross-section for modern, high velocity designs
-Exhaust features extra bowl and short turn material to accommodate all exhaust port shapes philosophies.
-Merged rocker boss pairs for improved valve train stability and support
-Extra material in the spring pockets to allow machining for larger spring diameters
-Heavy deck thickness ensures optimum gasket retention and allows for milling of the deck for smaller combustion chamber sizes
-Newly designed internal water jacket allows for highly efficient cooling without sacrificing extra material and overall strength
-Versatile mini-chamber can be machined from sizes ranging 40cc to 80cc without fear of thin material
-OE quality powdered metal seats and Edelbrock proprietary valve guides installed
-Heli-coiled rocker stands and exhaust flange bolts holes
61969 : Edelbrock / Lingenfelter LS1 CNC, complete with parts
![](http://www.edelbrock.com/advertising/web_images/LS1%20Heads/images/61969.jpg)
![](http://www.edelbrock.com/advertising/web_images/LS1%20Heads/images/61969cut.jpg)
61969 Edelbrock/Lingenfelter LS1 CNC features include:
-High quality Edelbrock manufactured casting, complete with seats, guides and heli-coils as listed above
-Completely CNC machined by Lingenfelter Performance
-202cc intake ports
-65cc combustion chambers
-Stainless Steel 2.02" intake / 1.57 exhaust valves
-Comp 918 Springs equipped
-All factory sensor, accessory and exhaust locations are to OE spec for a true bolt-on installation
-61979 will be available as a bare version of the Edelbrock/Lingenfelter CNC head, finish machined minus parts
Flow Numbers:
Intake flow 3.900" bore / 28" / R.300" entry / Lingenfelter SF 600 bench
0.200" 141.0 cfm
0.300" 200.3 cfm
0.400" 245.1 cfm
0.450" 264.8 cfm
0.500" 282.0 cfm
0.550" 294.6 cfm
0.600" 300.5 cfm
Exhaust flow 3.900" bore / 28" / no pipe / Lingenfelter SF 600 bench
0.200" 114.6 cfm
0.300" 162.3 cfm
0.400" 196.3 cfm
0.450" 202.6 cfm
0.500" 208.6 cfm
0.550" 213.7 cfm
0.600" 216.9 cfm
![](http://www.edelbrock.com/advertising/web_images/LS1%20Heads/images/61969exh.jpg)
![](http://www.edelbrock.com/advertising/web_images/LS1%20Heads/images/61969chmbr.jpg)
-202cc intake ports
Flow Numbers:
0.200" 141.0 cfm
0.300" 200.3 cfm
0.400" 245.1 cfm
0.450" 264.8 cfm
0.500" 282.0 cfm
0.550" 294.6 cfm
0.600" 300.5 cfm
0.200" 114.6 cfm
0.300" 162.3 cfm
0.400" 196.3 cfm
0.450" 202.6 cfm
0.500" 208.6 cfm
0.550" 213.7 cfm
0.600" 216.9 cfm
UNDER PRESSURE MOD
Great pics and info Jason....
Might make me put a set on the ole Christmas list.
From what I understand, the prices should be extremely competitive (read cheaper than almost everything else out there comparable) since Edelbrock has their own foundry and don't have to source in their cores.
Originally Posted by oange ss
these gonna cost an arm and a leg too ?
Originally Posted by Billiumss
Flow Numbers and price will determine their fate in the tough LS1/LS6 market.
[QUOTE=The Alchemist]I also like the fact that all of the bolt holes are helicoiled. I wish the factory had done that to begin with. Right now I have two manifold bolt holes that are toast and I'm not about to pull a head again just to have em machined and heli-coiled again.[/QUOTE
Agreed, heli-coils are just one of many finer details that make this a well thought out product.
LSxGuy widda 9sec Mustang
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Welcome to the site Jason and Edelbrock! I seen your LS heads at PRI and look forward to some future testing. I especially like that you own your own foundry and casting equipment. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
BTW I have some Edel. Perf. heads on my Turbo 5L Mustang and every time I tear up a motor, the heads have never been hurt and go right back on. Did have to replace the springs once, but that is all its ever needed.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
BTW I have some Edel. Perf. heads on my Turbo 5L Mustang and every time I tear up a motor, the heads have never been hurt and go right back on. Did have to replace the springs once, but that is all its ever needed.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Originally Posted by silverZ98
what kinda dates we looking at for these?
Originally Posted by JL ws-6
What is the valve angle on the heads, ios it stock, or altered?
![Icon Twisted](https://ls1tech.com/forums/images/smilies2/icon_twisted.gif)
