208/214 high lift cam
My brother has a 2000 chevy 2500, 4X4 pickup with the 6.0L and auto trans, only mod is a magnaflow muffler and no catalytic converters. He's interested in increasing power from idle to 5200 rpm,s , I think a 208/214 high lift (in the .550's) on a 114+4 comp cam would work well for his needs. I just wanted to run this by you guys to see if you think this would work for him.
Thanks
Thanks
Originally Posted by silverTA2002
112 will have more low end tq than a 114 lsa
99 2500
That cam on a 6.0L should be a stump puller if my assumptions on the cam specs are correct. I run a 206/212 .515/.522 112lsa installed on a 112 icl in my 5.7L. The torque increase is right off idle
PT's Slowest Truck
Here's the cam info page from performancetrucks: http://www.fastruck.net/caminfo.htm
Vinci has a bunch of truck cams, and Thunder Racing has this one that's intended for trucks:
Thunder Racing Custom "Old Man Truck" Camshaft - 214/220 .600/.525 115+2 LSA This is the perfect cam for someone looking for a stock range power band and stock sounding idle. Significant horsepower gains throughout the RPM range. No computer tuning required. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
LS1 Tech Administrator
Remember, a 6.0L will swallow a larger cam a little easier than a 5.7 (or even a 5.3L). Remember that when getting cam advice. You can go about 10 degrees more in duration than what would work well in a 5.3L.
I would recommend at least 212 in intake duration. You can keep the LSA at 114 if you like. You just want to put some advance in it to keep the peak power and torque down low. A 214/226 .559/.570 114 (+4) would work well if you're running exhaust manifolds.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
OLD thread, but a good question. Any cam gurus wanna chime in on this?
