Valve Spring Swap... and the Valve goes down with the spring
Im using the tool suggested Here
compress it just til the valve opens and the air is coming out
then hold the pointed end of a phillips screwdriver on the retainer right by where the flat part of the retainer and the little hump meet(i actually used the phillips bit from a multiscrewdriver) and tap the end of the handle lightly with a hammer or your rachet a couple times and the valve should pop right up along with the keys
ryan
Started going real slow when I started compressing them and they popped. Couple of them I had to coerce into popping loose.
Just got the rockers on hand tight... going to torque them down to 20 and then turn the motor over by hand and feel for resistance.
Thanks for all the help. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Tally TransAm... that tool is the $h1t!!!! Made it so incredibly easy it's pathetic.
Did hit the top of one valve with the retainer when i was compressing it though... backed it off and compresser came on and pushed it back off.
Hopefully everything else from here goes nice and smooth.
Oh... quick question... crank pulley... tap it on soft with a mallet??? Or throw a little pb blaster or wd-40 on there to start it?
for the crank pulley, i bought a bolt of the same threads that was longer, and a bunch of washers to use as spacers, and started it with that. i didnt like the idea of hitting it with a mallet, might work though. im sure that and some wd40 could get the job done
ryan
