New 243 Patriot CNC Ported Heads
Old 12-19-2005, 12:18 PM
Gunnar@Patriot's Avatar
Default New 243 Patriot CNC Ported Heads as low $845.00 per pair !!
When we posted this on Friday, there were a few options that we can make available to customers that were left out. So in order to help everyone sort out what is best for them, we have listed all options and sorted the options by price.
New Factory 243 Patriot CNC ported bare heads: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be bare with no valvetrain.
Pricing is $845.00 per pair, no exchange.
New Factory 243 Patriot CNC ported heads with Ferrea valves: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with Ferrea 6000 series 2.02"/1.57" stainless valves. No springs will come with this particular option.
Pricing is $1,075.00 per pair, no exchange.
New Factory 243 Patriot CNC ported heads with OEM valves: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with OEM (non-sodium) valves along with our orginal Patriot Gold .650" Dual Springs, Ti Retainers, Super 7 Locks, Viton Rubber Seals, and Machined spring Bases.
Pricing is $1,095.00 per pair assembled, no exchange.
New Factory 243 Patriot CNC ported Stage II assembled heads: These will be new 243 GM castings that are CNC ported with our stage II program and have our five angle valve job. The combustion chambers will be 64cc and extra milling is available at no extra charge. These heads will be fitted with Ferrea 6000 series 2.02"/1.57" stainless valves, Patriot Gold .650" Dual Springs, Ti Retainers, Super 7 Locks, Viton Rubber Seals, Machined spring Bases, and Bronze Valve Guides. These heads are the best buy for the money. They are assembled with the highest quality parts at the best price available. When comparing apples to apples, you will find that these heads are simply the best value on the market.
Pricing is $1,395.00 per pair assembled, no exchange.
If anyone has any questions, please let us know. These heads have been selling fast so get your order in ASAP.
Old 12-19-2005, 12:46 PM
snketr's Avatar
Flow #'? I didn't see the other post.
Old 12-19-2005, 12:48 PM
These will flow just like our current LS6 style stage II head. 300-304 @.600".
Old 12-19-2005, 12:49 PM
STRIPSTAR's Avatar
Thanks for great prices and options. I think alot of cam only cars with good valve springs should take you up on the bare + valves deal. Is a milled 243 gonna produce the same results as an equal 5.3 casting?
Old 12-19-2005, 01:31 PM
We can mill the 243 casting to yield the same compression as our 5.3 heads. As far as flow, the 243 castings will flow better than our stage II 5.3 heads.
Old 12-19-2005, 03:37 PM
2xLS1's Avatar
OEM as in longer hollow sodium filled LS6 valves or OEM as in stock LS1 valves?
Old 12-19-2005, 03:53 PM
snketr's Avatar
So would they flow better on a 4.030 bore than the 3.905? I've got a stock motor now but building a 408. If I stuck these on my stock shortblock now would they be sufficient for my 408?
Old 12-19-2005, 04:26 PM
No, they are no the sodium filled valves. Corrected the post to reflect this.
Old 12-19-2005, 04:32 PM
The flow would be greater on a 4.030" bore. You could use these on a 408. However, most customers run a 2.08"/1.60" valve on the 408 (which is also the valve size we suggest). If you wanted to get these or our LS6 style heads, we could increase the valve sizes to 2.08"/1.60" at a later date for a minimal charge. PM or give us a call if you have anymore questions.
Old 12-19-2005, 04:44 PM
Z'mnypit's Avatar
Im running the Patriot stage III LS6 heads, on my 408 with 2.08/1.60 valves. With a stock ported TB & an LS6 intake in an A4 with a 3500 stall, car put down 440hp N/A (locked) & 620hp (unlocked verter) on a TNT 200 shot. I love my Patriot heads, havent had a chance to take it to the track yet (damn rain) but I dont think I will be disapointed.... TTT for a great deal & guy to deal with.
Old 12-19-2005, 05:45 PM
Ksett's Avatar
That doesn't sound like a great endorsement considering you have a 408, unless the cam is really, really small.
Old 12-19-2005, 07:25 PM
Z'mnypit's Avatar
The cam is fairly small, its a 244/248 .613/.615 113lsa. The LS6 intake is killing it. But honestly what do you expect? 500 hp in an A4 with a 3500 stall, stock ported TB, LS6 intake, 10.7-1 CR? I dont think so. The 6spd guys are making just a lil over 500 so you do the math!
Old 12-19-2005, 08:13 PM
1QuickT-A's Avatar
Just out of curiousity...
What are the highest numbers made by anyone with the Patriot Stage III LS6 heads on a 408ci motor with the Fast 90/90 setup and a good sized camshaft??
Old 12-19-2005, 10:18 PM
Raped-Ape's Avatar
do these come with the free mls gaskets and headbolts as well?
Old 12-19-2005, 11:29 PM
waterbug1999's Avatar
May I ask then what is the difference? LS6 "style" are 200 cheaper then "New 243 Patriot CNC Ported Heads". What is teh advantages then?
Old 12-20-2005, 02:34 AM
konryod215's Avatar
New Factory 243 Patriot CNC ported heads with OEM valves, do u have any flow numbers?
Old 12-20-2005, 05:27 AM
PREDATOR-Z's Avatar
LS6 "style" are 6.0 heads with welded chambers (64cc/59cc)
243 casting are new GM LS2 castings (05+)
The difference is that welded 6.0 59 cc still keep more PTV clearance to allow bigger cams than if you milled the 243 to achieve 59cc.
I doubt seriously there is a major power difference all components and chamber size being the same, but milled 243's might flow a little less.
In any case, this is a really good deal with Ferrea/dual spring setup.
Old 12-20-2005, 08:17 AM
Predator Z is correct in his answer. If you have anymore questions, please let us know.
Old 12-20-2005, 09:02 PM
Jpr5690's Avatar
when you say a bigger ptv clearence on a 6.0l head what types of lifts could we use that we couldent use on the 243 head also how does this effect compression ..
for example lets say was going to buy a set of 5.3l heads from tsp and use them with a ms3 cam but have to fly cut IF i used your 6.0L heads and had youguys set them up to have the same valve sizes and combustion chamber size would i have to fly cut also would this mean i have a different compression.. and if this is so would i gain more by milling your heads further and still flycutting????
***bare with me im still learning so the Above post might not be 100% logical***
Old 12-21-2005, 12:08 AM
PREDATOR-Z's Avatar
PTV has little to do with lifts and has to do with duration amount used, valve events and size of valves.
The MS3 will fit PP 243 with stock valves and no mill.
It might even fit PP 59 cc with 2.02/ 1.57 valves ( not sure though)
But with bigger valves, the way to do this is stick the cam in and measure PTV.
No sane sponsor here will give you a definite answer, it will be it "should" but "better measure", which is sound advice when you're playing with cams that size.
Quick Reply: New 243 Patriot CNC Ported Heads
