236/240 600/600 112LSA okay for DD?
is a cam around that size okay for a daily driver? i'll defintely need a tune, but anyone running a cam like this?
I was looking at the
Product Line: Crane Z Series Hydraulic Roller Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,000-7,000 RPM
Duration at 050 inch Lift: 236 int./240 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.600
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.600
Lobe Separation (degrees): 112
Grind Number: HR-236/353-2S-12
as well as the
Product Line: Competition Cams Xtreme Energy Camshafts
Basic Operating RPM Range: 2,800-7,200 RPM
Duration at 050 inch Lift: 238 int./240 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.605
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.609
Grind Number: LS1 XER287HR-12
I'm personally thinking the 1st one seems like a good cam...pretty good power curve compared to the 2nd one.
are they good for a DD?
Chad
as well as the
Chad
thanks guys...glad to hear.
someone said think about what you want to shift at.
how much can you safely increase the RPM limiter? whats the weak link in the valve train?
when I get a cam im defintely replacing springs, pushrods, what else? rockers?
6500 to far? new to the ls1...
Chad
Chad
Originally Posted by moeZ28
i have the comp cam you are looking at, but i cant really tell you anything b/c my motor was gettin wore out before i got it. seems like it has pretty good low and midrange for a cam of its size, but its more of a top end cam.
pushrods? retainers?
Chad
Aussie LS1 set me up with a custom Comp Cams 236/238 113 with an awesome SD tune.
Pulls 60 @1,700 rpm in 6th with 3.9:1 diff gears no worries and idles beautifully with minimal lope, as has been said before it all in the tune. Note that my tune was very thorough entailing more than two days as my tuner and I are pretty pedantic about nice drivability and slow sped smoothness
Do you guys think you could drive with this cam for a 600 mile trip? I'm asking because my buddy is putting a similar cam in his camaro and wants to drive from North Carolina to New Jersey (590 mi). What do you think?
Originally Posted by Nimitz87
what springs did you go with?
Chad
Chad
