How many of you f13 guys are running stock lifters without problems
Old 02-18-2006, 01:16 PM
ls1greyhound's Avatar
Default How many of you f13 guys are running stock lifters without problems
I'm Thinking about an f13/comparable cam. I would like to no what (if any) risk is involved with just using stock lifters.
Are you running stock lifters with a f13/comparable cam? How many miles do you have on your stock lifters with the new cam.
Thanks
Old 02-18-2006, 01:17 PM
94formulabird's Avatar
Just get the comp oe replacement lifters...they work great
Old 02-18-2006, 01:19 PM
I don't want to remove the heads
Old 02-18-2006, 01:25 PM
rollinna65's Avatar
I've got 15k on the lifters with the cam, 87k total on the motor. I won't know how they look until the summertime when I change out the heads and throw some new ones in there.
Old 02-18-2006, 05:19 PM
GuitsBoy's Avatar
I installed my f13 at 75K miles. by 88K 5 lifters had started to come apart.
http://www.ihearyou.com/~tony/lifters/lifters-001.jpg
http://www.ihearyou.com/~tony/lifters/lifters-003.jpg
http://www.ihearyou.com/~tony/lifters/lifters-005.jpg
Some people dont have any problem with lifters, however I have seen atleast three threads about the same thing happening on an f-13 cam. Maybe its coincidence because the f13 is becoming one of the most popular cams around.
For what its worth, I did notice the cam still had tooling marks and groves on the lobes when i bought it. they wernt polished smooth.
Old 02-18-2006, 05:23 PM
WS6FirebirdTA00's Avatar
i reused my stock ones.
guitsboy, what kinda symptoms did you notice when they started to act up?
Old 02-18-2006, 05:30 PM
GuitsBoy's Avatar
Rhythmic tapping in sets of 3 or 4 every few seconds. Sounded like someone picking up a handful of marbles and dropping one at a time into a coffee can, then it would go away for a few seconds so the motor could pick up another handful of marbles. At first I though it was my exhaust banging, but it didnt corespond with bumps in teh road.
I tried reusing the f13 cam that had a few small pits from the broken lifters, but it tore up the new set in about 6K miles. Now Ive got the heads off and cam out... All winter has been unseasonably warm here in the northeast, until of courese i needed to tear down my daily driver. Now its frigid again.
Old 02-18-2006, 05:41 PM
what lifters are you going with now? and whats the part number?
Old 02-18-2006, 06:01 PM
sprydncamd ta's Avatar
ive had stock ones for about 3000 miles and now have the comp oe replacments
Old 02-18-2006, 06:24 PM
they expensive? the comps that is
Old 02-18-2006, 06:32 PM
Xtnct00WS6's Avatar
I believe he's talking about these:
http://www.thunderracing.com/catalog...vid=3&pcid=107
Part number: 63-850-16
Old 02-18-2006, 06:34 PM
cool thanks. any issues with those lifters? i think the ones i hear people complina about are the "r"
Old 02-18-2006, 07:13 PM
GuitsBoy's Avatar
I went with melling lifters from futral. Theyre pretty cheap. The comp 850's are a few bucks more. The 850's dont lose their pin like the 875's do (comp -R's).
Old 02-18-2006, 07:19 PM
cantdrv65's Avatar
Post
Hmmm, pits like that are caused by either a bad surface on the cam to begin with or lack of oil to the lifters....I never had a stock lifter fail, and but then again Ive always run comp cams....
Old 02-19-2006, 10:34 AM
35thls1ss19's Avatar
i have 28k on mine you think i sohuld change them? i was planing on reusein stock
Old 02-19-2006, 10:41 AM
i would reuse the stockers if there is no visual signs of wear. if u get in there and see some wear or damage replace them all
Old 02-19-2006, 11:44 AM
How many of you cam only guys went through the trouble of changing just your lifters and not the heads.
Old 02-19-2006, 11:48 AM
Mike94ZLT1's Avatar
You have to pull the heads to change the lifters?! I don't remember having to do that.. I'm probably thinking of the LT1 though.
Old 02-19-2006, 11:54 AM
BLAKE 01 WS6's Avatar
when mine is cold(never does it when warm) it makes a weird kind of clattering sound on initial take off, but i also heard it pre-cam when my lt's were installed. has gotten a little worse after f-13. is this the sound that they make when they are going out??
Old 02-19-2006, 11:57 AM
Yes the lifter vally is under the head.
