Whining Noise After Cam Change
#201
If you go to their website, you can spec any lobe lift you want in .05" increments.
I just picked less exhaust lift because it seems unnecessary since the valves are already small, so there isnt much shrouding going on.
I gave intake a bit more lift because the valve is so huge (2.08") in a 3.905" bore and it's heavily shrouded.
#202
Start it up like I am with nothing reinstalled to see if the whine goes away before you buttoning it all back up.
#203
Hmmm, I am still on the same cam retainer plate from 1999. The gasket looked a bit flat.
I think I might order a new one and postpone the buttoning up.
Also, anyone know about the n-motion timing sets?
#205
#206
#207
Yep, everything off. I start it, let it idle for like 5 seconds to get the oil pressure up, do a quick back and forth rev 1500 to 2500 rpms then shut it back down. You can hear me revving it at the end of the video and there is not a hint of whine.
#212
Your cam is a paper weight if they don't warranty it. May as well just take $380 and light it on fire. I'd fight hard and slam them everywhere.
#213
I talked to Alex So at comp. He told me the same bs, I told him I was sending back regardless. I send them pics today you can see the rough cut on the lobes.
#215
I had the n-motion dual set fitted, when taken off after 10-15000km it had stretched.
I fitted a Cloyes extreme duty C5R chain with hex a just gears, trick flow damper bracket & LS2 damper...huge mind weight lifted.
#218
I know i will be going with a Cam Motion cam for my build. I think it is ridiculous how Comp blows people off, like there isn't a problem. It took Martin as the vendor to open their eyes. If i were Tick, i would drop Comp as my grinder. This is going to cost them business. Who cares if they warranty the cam, you still have to eat the labor and materials to re-install it. And why would i want another possible junk cam under warranty? I'd ask for a refund and take my business elsewhere.
#219
Can you send me your email. iPhone won't let me post pics on this forum.
I would assume they would know this problem if one person knew it. I sent Alex from comp a link to this thread along with pics.
