Cam with great off-idle power, 5800-6000 RPM peak?
Looking for some ideas for cams with great off-idle power, and then more as you go up, peaking relatively early at 5800-6000. This will be for a 6-speed '02 Corvette coupe with Z06 exhaust, otherwise pretty much stock. Although I will run it on 93 locally, I want it to be able to run on 91 on a road trip if needed. Idle quality is not important, and it doesn't need to pass emissions. Annual spring maintenance is not a problem. I may add AFR 205s later. Otherwise I want as much torque, throttle response, and horsepower as I can get within those parameters. Must have great power and response under 2000.
There's the Thunder Racing Old Man Cam and CheaTR, and I also considered an LS6 cam with rockers., although high-lift rockers get expensive in a hurry. Other suggestions? It seems like most of the sub-224 cams are pretty short on lift, the TR pieces excepted. Your thoughts appreciated.
I have had an F13 (112+4) and you are going to give up power under 2000rpm that is all there is to it. I have to ask why such a low rpm number requirement???
Just in case it matters I made 350rwtq (sae) at 2400 with my F13 and all the other mods in my sig...
F13 (112+4) and AFR205s (62cc) NO FAST
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Maybe I got spoiled on big-blocks when I was a kid...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I'm willing to compromise on valvetrain durability over what the factory could accept, and perhaps take another 10 degrees or so duration over stock, but I think more than that will lose too much under 2000. But I'm no expert, which is why I'm askin'.
Thanks for the replies so far.
I just ordered a 224/228 grind from ThunderRacing. Its the cam Patrick G is running. Needs some good valvesprings though as it has a lot of lift and very quick ramp rates. .633/.639" lift or somewhere around there. 110* LSA. I'm hoping for close to what you're asking. I want my power to kick in around 2000RPM or a bit lower and make power to 6000-6200RPM. 6500ish if need be.
Patrick says it makes killer low end torque and doesn't lose much compared to his CompCams 234/238 grind that he had in there.
Originally Posted by Ragtop 99
Want torque with stock manifolds...check out my cam
https://ls1tech.com/forums/showthrea...=440051&page=2
So you went with this? 210/222 112 110 .595/.581
I'm rusty, that notation is 112 LSA and 110 ICL, right? How are you guys getting all the numbers to calculate the actual timing events?
Comparing that cam to a TR Old Man, it's a bit shorter on intake, longer on exhaust, and narrower. Out of curiousity, why did you go narrower?
Whoa!
The key to low rpm use is going to be limited overlap and keeping the IVC in check. If you are willing to do valve spring maintenance, what you are looking at is an aggressive cam with modest seat timing.
Something like the Thunder Racing CheaTR (XER lobes, 214/230 with 117lsa) or a custom with an LSK intake lobe and maybe a little less exhaust.
In any case you will new valve springs and check piston to valve clearance. The small intake and big LSA should allow out to get by without notching the pistons.
Originally Posted by UltraZLS1
You wont notice much low end loss at all with something like the tr224 or the tsp 224r
My old xe 224 cam I had didnt give up anything down low that I could notice.
And xe-r lobes have a stronger low end than the xe lobes.
Go with a 224 and call it a day.
i have the 224 581 114 lsa cam and could not be more happy.
