Found a new way to clean head bolt holes
I didn't think there was any great method at removing all the coolant/oil from the bolt holes, so I had to invent something that was more effective and faster than the paper towel method. Since I used the shop-vac prior to removing the heads, I thought I could utilize it again in some way.
After about 30 seconds of thought, I thought I could try to fit a milk jug lid over my attatchment, then poke a hole in it for a straw. Well, the lid didn't exactly fit, so I turned it over and put gasket sealer on it and let it sit overnight. The next day it was solid as a rock, so I poked a hole in it and shoved in one of those ribbed thermus-type straws, then sealed it w/ RTV.
It worked like a charm, with one exception. Remember if you blew in those straws, it would make a high pitched whistle that made you want to blow your brains out? Well times that by 50 or so. So while doing this, ear plugs are a must. Overall, it took me about 5 minutes to clean out all 10 bolts thoroughly.
And a headswap wouldn't be complete with out the ceremonial Baptisim of blood.
2 hours later and 1 pint lighter, the heads are on.
Originally Posted by Xtnct00WS6
You're eternally bonded to your engine once you bleed on it
BTW, how did you get the block surface so clean? I used a plastic ice scraper and mine doesn't look nearly that good. It's flat though, so I guess that's all that counts.
Nice idea! For my head swap, one of my friends actually left a chunk of tissue on my engine from the valvecover ledge on the stock heads. Those damned things are SHARP! I didn't think to take pics...oh well. The best part about it was...it was Hilton's hand and not my own!
Galen
Galen
