Ms4
Old Jun 7, 2006 | 03:09 PM
  #101
blkZ28spt's Avatar
Originally Posted by 1CAMWNDR
You can run N2O with any cam. A certain cam is not gonig to prevent you from using the juice. A N2O specific cam will gain more on the bottle, but a N/A cam will still respond well to using N2O.
And as somebody else mentioned the MS4 will certainly take well to the bottle, to a point. It is relatively similer to the MS3, which loves it, and maintains the strong traditional split that nitrous likes. Only possible issue I see is the increased overlap losing some of it out the back end, but until you get into large shots (200hp) any and every cam should work just fine.
Old Jun 7, 2006 | 03:20 PM
  #102
monicaz28's Avatar
Just because you CAN run nitrous with any cam doesn't mean that you should. Some cams don't get as much from using it. I was wanting to hear what Texas Speed has to say and if they've tested the cam with nitrous. The Ms3 definitely likes nitrous, and I want to see if this one will be the same, or more for cam only setups such as the T-Rex.
Old Jun 7, 2006 | 03:46 PM
  #103
jermzz's Avatar
When I called TSP to ask them for a good n20 cam for my darton 420ci they suggested the Texas Giant which I then purchased.
I think I was talking to... Jason? He said LS1's seem to like a 4 - 6 split in the duration for the best results on nitrous. This split is only 3, but who knows maybe they found something esle out.
Old Jun 7, 2006 | 05:20 PM
  #104
s346k's Avatar
Originally Posted by s346k
how much advance?
Old Jun 7, 2006 | 06:37 PM
  #105
SSilverSSurfer's Avatar
Originally Posted by Zach@Texas-Speed
248/254, .622"/.614", 114 LSA
well i guess i made up my mind on what cam im going with
Old Jun 7, 2006 | 06:56 PM
  #106
formula402's Avatar
me too.....
Old Jun 8, 2006 | 08:01 AM
  #107
BAN-LS1's Avatar
can one of the guys at TSP post a chassis dyno graph for the test cars with a list of mods
Old Jun 8, 2006 | 08:53 AM
  #108
BQTransAm's Avatar
The MS4 sounds bad ***... but whats the story on the Texas Giant? is that a cam only cam?
Old Jun 8, 2006 | 09:50 AM
  #109
IT P.S.I.'s Avatar
the tx giant is tsp's big cube cam.
frank
Old Jun 8, 2006 | 11:58 AM
  #110
SVT THIS's Avatar
The TRex is not just a great cam only cam. It will work great with nitrous on the street (under 200 shot) and will respond great to a good set of heads and intake.
On a side note, I want to see a dyno with the MS4 and there PRC CNC LS6 street head (bumped up compression, flycut pistons)!!! *wink wink* TSP!
Old Jun 8, 2006 | 01:31 PM
  #111
HOSS's Avatar
If you don't plan on running a big shot, being a 300 plus shot, why worry about how a cam will react to nitrous, considering you will be off the bottle like 90% of the time. Any cam will respond well to nitrous, even the stock one.
Old Jun 8, 2006 | 01:39 PM
  #112
RoastEmSS's Avatar
Old Jun 8, 2006 | 01:54 PM
  #113
CRZYPWR's Avatar
I just might try this one out... and if my car will get more rwhp and better times than my 243/249 I got.
Old Jun 8, 2006 | 01:56 PM
  #114
CRZYPWR's Avatar
What is needed to install this in a 347 ? Or its just made for bigger ccs ?
Old Jun 8, 2006 | 02:41 PM
  #115
SVT THIS's Avatar
It's made for stock cubes. If you already have the TRex in there you should be fine as long as you did the TRex install right.
Dual springs, pushrods, oil pump, timing chain and you're set.
Old Jun 8, 2006 | 04:20 PM
  #116
Zach@Texas-Speed's Avatar
Here is the start up and idle video of the cam, the car is a daily driver 2000 C5 with open cutouts
http://www.texas-speed.com/Videos/ms4_0001.wmv
enjoy!
Old Jun 8, 2006 | 04:59 PM
  #117
CRZYPWR's Avatar
Any #s of Giant with stock heads ?
Old Jun 8, 2006 | 05:06 PM
  #118
ThirdGenLS1's Avatar
LOL, i can't get over the the music in the background of all of your guys videos for the ms4.
Old Jun 8, 2006 | 05:38 PM
  #119
IT P.S.I.'s Avatar
enjoy!
sick, i cant wait
Old Jun 8, 2006 | 06:29 PM
  #120
alans02z's Avatar
What gear are you guys recommending or did I miss that already? Are 921's good enough?
