everyone with cams no TC, ?
You will get far more performance gain from a converter, even a small one, than a Hotcam.
There is a reason not many people do this. Actually, there are several reasons.
Let us know how it goes after it's been in for a few weeks.
As for being a pig off the line, it was anything but because of the surging. Its more a pig off the line at low rpms with the verter. But once you wind it up, nothing (cam, heads, exhaust) compares to the performance.
I had my ASA cam in my car on the stock torque converter for a little over a year. The reason I did this is because my original plans were to swap my 4l60e for a t56 setup, so I didn't want to throw money at the auto that I planned on yanking anyhow. I tuned it myself, driveablility was perfect and I had it idling at 700rpm. It pulled on the brakes a little in gear at a stoplight but not bad and it never would try to die. The car wasn't "a dog" down low (no worse than stock) but it really took off above 3k rpm. The dead spots that a4 cars suffer from between shift points were even worse after the cam since it's power is made at higher rpms.
Fast forward one year and I see my financial situation isn't going to allow a pricey t56 swap for several years (wife getting masters degree) so I threw a Fuddle 3600 in it. It was INCREDIBLE how the car changed with a stall and how much faster it was. Coming from someone that's done it....do the converter first. While the cam made my car faster than stock and it sounded badass, there's no comparison in the performance gain the converter will give you over the cam by itself. Needless to say, I no longer wish I had a t56 in my car.
) chuckles I wanted to see the I drive a stick choice.. hehe
