Timing chain questions!!!
Old Jun 19, 2006 | 12:22 PM
Pewter02TA's Avatar
Breakfast Fanatic
Default Timing chain questions!!!
What would be the symptoms of having slack in the timing chain??
Old Jun 19, 2006 | 12:24 PM
Lithium's Avatar
SSU's Drunk Typing Whore
What chain did you put on? I believe some have more slack then others...
Old Jun 19, 2006 | 12:33 PM
Pewter02TA's Avatar
Breakfast Fanatic
I still have the stock chain with 40,000 miles, but I have a random missfire and its not fuel related, pushrod, ignition, or bent valve.
Old Jun 19, 2006 | 01:04 PM
Lithium's Avatar
Seems a lot of people have had slack in their stock chains - https://ls1tech.com/forums/generation-iii-internal-engine/325345-so-i-guess-ls1-s-run-lot-slack-timing-chain.html
Old Jun 20, 2006 | 09:00 PM
Pewter02TA's Avatar
Breakfast Fanatic
anyone?
Old Jun 20, 2006 | 10:26 PM
SSDoubleK's Avatar
When I changed out my timing chain with my cam install, it had a fair amount on play in it. I changed over to the LS2 timing chain and it did fit tighter.
Old Jun 20, 2006 | 11:37 PM
|Drew|'s Avatar
But what are the simptoms of having to much slack????
Old Jun 21, 2006 | 12:04 AM
Lithium's Avatar
Is it possible to have to much slack in the chain? what problems can that cause? I am lost now lol sorry!
Old Jun 21, 2006 | 07:20 AM
slow trap's Avatar
maybe slight timing differences but i don't think it would be enough for misfires.are you running a colder plug like the tr6 ?
Old Jun 21, 2006 | 10:42 AM
GuitsBoy's Avatar
Unless you get enough slack to cause a mechanical failure, the only thing I could see it do is retard yoru cam timing. This will result in moving your power band upwards in the rpm range. While it may lose a little low end since it moves max torque upwards, if anything it may increase top end HP. Atleast to a certain point until it stretches too far.
Old Jun 21, 2006 | 11:04 AM
ShevrolayZ28's Avatar
The effect of slack is an interesting consideration. I guess it would make for a slight variation in valve timing, but would it only be in the retard direction? I would think that on deceleration the crank would cause the cam to decelerate. Would this move the slack to the other side of the timing gears and cause slight advance?
I wonder if it really makes a significant difference.
Old Jun 21, 2006 | 11:08 AM
GuitsBoy's Avatar
During deceleration, the drivetrain is still turning the crank and not the camshaft. Yes, the cam has inertia, but I think overcoming the valvesprings might be enough to keep the inertia from spinning faster than the crank... Although, im basing this soley on my imagination of the way things work...
Old Jun 21, 2006 | 11:20 AM
I can't see, said the man with 20/20 lol.
Someone needs to build a transparent motor so I can see exactly what the heck goes on in there.
But I think I understand what your saying.
Acceleration of car: the crank accelerates the drive train and the cam.
Deceleration of car: the drive train deceleratres the the crank but the crank still accelerates the cam. (In other words, the cam is not applying a force to the crank in a dircection so as to reduce crank rpm.)
Old Jun 21, 2006 | 11:49 AM
Pewter02TA's Avatar
Breakfast Fanatic
Nope Im runnin tr55's but have recently changed them.
Old Jun 21, 2006 | 11:52 AM
daryl2cb@yahoo.com's Avatar
think your recent plug change is the issue, look for a not fully seated plug wire.
Old Jun 21, 2006 | 12:22 PM
Pewter02TA's Avatar
Breakfast Fanatic
I have checked that many times. Any other ideas?
