How much to milll with Torquer2 + stock heastonsds + -4cc pi
I have the engine out and tried using the scr/dsr calc's but I dont know enough of the details.
Can someone help me calculate what head gasket to use or how much to have the stock 241 heads milled for max scr/dsr? Want to run on pump gas and I'm using the mahle -4 cc valve relief forged pistons. I've already called TSP. I have no money left for LS6 heads.
acording to my "rough" calculations, if you use a .040 cometic,shave your heads .030 or whatever it takes to get your heads down to 61 cc,cr will be around 10:9,i think.with the torquer on a 112 dcr will be alittle over 8.1,if you get it 112 +2 it will be right at 8.3 if my calcs are correct anyway.
You are pissing in the wind on 241 heads.
Get a set of stock LS2 castings if you want the cheapest route. Those are ~ 62 cc
and mill .018 with .040 Cometic
You'll get ~11.2:1 and ~8.5 DCR
I was reading that every .006 off the head is -1cc correct?
Originally Posted by nytoy
Just the man I was looking for to respond. I'm trying to put this motor together tonight, So it wouldnt be worth it to mill the stock ls1 heads and use an gm mls gasket then? I just figure since I have them off the car now anyways. The stock ls1 heads are 66.7 cc, with a stock .053 gm mls head gasket would it be worth it just to mill the heads for any increase just for the time being?
Problem is the 241 will require a significant amount of mill. to make desired impact.
You'll require 57 cc at least to make close to 11.0:1 SCR and 8.35 DCR
Doing that would kill your flow on stock heads.
Cost:241
Mill: ~$100
push rods (shorter) ~$125
Cometics ~$175
That is to get close to 11.0:1 with 59.5 cc/.040 with reduced flow.
That is why $450 for LS2 stock castings is a better choice if you are on tight budget.
.005>.006 for every cc.
Cost:241
Mill: ~$100
Cometics ~$175
Cost:241
Mill: ~$100
Cometics ~$175
And how much shorter to I have to get the pushrods? I think I calc'd the T2 cam needing 7.425 with stock rockers before.
Use 7.40 p-rods
Because you shorten distance by .015 on heads and .014 on gasket
.015+.014= ~.029
Tv2 base circle is .09x smaller, take 1/2 of that is .045 effective radius
.045-.029= .016
7.40's will be perfect.
.015+.014= ~.029
.045-.029= .016
I have the 112 +2 and milled my 241# heads .040. Im still using a 7.400 pushrod. My SCR is 10.9 and my DCR is about 8.2 with very small flycuts.
Mill as much as your comfortable doing and use a smaller gasket for a tighter quench. Id love a touch more compression myself.
I wonder what the difference in HP would be, between the stock ls2 243 head milled and a TSP stage one budget ported LS6 head milled with the same compression and dcr
