Do you need head dowels if you have head studs?
Originally Posted by cantdrv65
Absolutely. The studs do not locate the head at all.
Originally Posted by Gearhead1
Newb question. I'm doing heads and cam next week.... and yes, I'm using studs. Do the LS1's from the factory not have dowels?? Do I need to purchase some??
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
Just make sure when you pull the old heads the dowels are still in the block. Sometimes they go with the old head, in which case you will have to remove them and tap them back into the block. Very simple process, nevertheless one you do not want to forget....
Also if you lose one, they can be very difficult to find at machine shops....They are not the same as the old SBC.
The way the first question was phrased kind of threw me. I thought maybe LS1's didn't have them. I've never known an engine to not have them, but I've never had an LS1 apart and thought maybe they were the exception to the rule.
