347 ci piston ring gap??? nitrous motors
Old Aug 24, 2006 | 04:13 PM
99SLOWC5's Avatar
Default 347 ci piston ring gap??? nitrous motors
I'm finally starting to re-build my motor. My question is what does or has everyone filed their piston ring gaps for their nitrous engines?
My info was
.007" x bore for the top ring
.008" x bore for the second ring
top ring
second ring
oil ring
The info I got told me minimum of .015" on the oil rings. the wave ring right now has ZERO clearance. Does that Wave ring need that .015"? The rings that go above and below the wave ring have the spec'd .015" clearance.
Thanks
JEFF
Old Aug 24, 2006 | 08:14 PM
99SLOWC5's Avatar
nobody here files rings
come on....
Old Aug 24, 2006 | 08:49 PM
AmericanMuscle313's Avatar
What kind of rings are they? My Childs and Albert Dura-Moly rings came with a sheet on recommend end gaps for different uses.
The recommend end gap was .0045 per inch of diameter bore for nitrous use on the top ring (that was the MINIMUM recommend gap, so Im guessing for a really big shot of nitrous 500+ you should go bigger?). I cant remember what the second ring was. The wavy one should not need to be gapped but you should double check with the manufacturer. The other two oil control rings (3rd groove) should have a minimum and maximum gap supplied by the manufacturer that must be checked with a feeler gauge.
Best thing to do would be to call the company that makes your rings and see what they recommend. Measure twice, file once. then measure again.
Old Aug 24, 2006 | 09:11 PM
99SLOWC5's Avatar
these are MAHLE pistons and rings. Forged of course
JEFF
Old Aug 24, 2006 | 09:18 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Don't worry about the oil ring as long as the scrapers are at recommened.I believe on my old 346 nos motor i was at .26 top .28 on the lower.Your better a little bigger when it comes to nitrous.
Old Aug 24, 2006 | 09:26 PM
tuff's Avatar
My info was
Thats .27 on the top and .31 on the second.
Old Aug 24, 2006 | 09:36 PM
99SLOWC5's Avatar
My info was
the .027" and .031" is what I'm set at now. I spray 150 before, now planning on more. Just lookin' for someone to back up my thoughts first LS1 build
JEFF
Old Aug 24, 2006 | 09:50 PM
tuff's Avatar
Id go .28 .30.I like just having a .02 spread between the two rings.Your better a little more loose on the end gap if you plain on spraying a big dose.Last thing you want is to have them to tight on the bottle.
Old Aug 25, 2006 | 05:35 PM
mind's Avatar
i just filed mine last night.
347 with je 3.905 pistons and total seal gapless top ring
the rings were supposed to come pre gapped and the machine shop guy said just throw them in and don't worry about it. the seconds showed close at .024 on every cyl so i left them alone. the tops were way tight at .023 instead of the suggested .031.
i filed the tops to .031
i plan on using a 200 shot as well.
sounds like were gonna have the same setup, which cam you going to use?
i can't decide. it's a DD and i want my g/f to be able to drive it so i can't go with a huge lope :-/
Old Aug 25, 2006 | 05:43 PM
99SLOWC5's Avatar
i run the 233/239 TSP cam
JEFF
Old Aug 25, 2006 | 06:01 PM
Phil99vette's Avatar
7 Second Club
I've built a few motors running a 150 and 200 shot with 22/24 on a 3.898 bore or 3.905.
Phil
Old Aug 25, 2006 | 09:19 PM
mr2guru's Avatar
I just had LME build me a 225-250 shot 346 and they set it up with .027/.020 on weisco nitrous pistons.
