Difference in cranks, truck engines vs ls1's
Alright, I was reading this book on ls1s/ls6's and they mention that the gen 3 truck blocks have different crankshafts. nearly identical excet the rear end of it is larger than the ls1/ls6 models. When building up a truck engine to be mounted in a truck, could I use any ls1 crank or do I have to use the ones meant for the trucks? Only one I could find to fit a 5.3l block on summit was $1050.. way more than the 400$ scat forged cranks. Anyone know what the deal on this is?
Thanks!
-Lurius
Thanks!
-Lurius
Thanks!
-Lurius
Thanks!
-Lurius
So then I could use an LS1 crank in an 02 5.3l block? I was worried because all I found listed under 5.3L was one for $1050 on summit lol, im loking more 400$-500$ range
Thanks guys,
-Lurius
Thanks guys,
-Lurius
Thanks guys,
-Lurius
Thanks guys,
-Lurius
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Thanks guys,
-Lurius
Thanks guys,
-Lurius
Originally Posted by Cop Car
yes, but its the same stroke as the 02 5.3 crank... why would you change it?
-Lurius
dont start with a 5.3 block, that would be a huge mistake
spend an extra couple hundred bucks and get a 6.0 block
-Lurius
