For those with long tubes!!!
Old Jan 21, 2002 | 02:46 PM
SSG-Z28's Avatar
Default For those with long tubes!!!
Do you have a lowered car? If you do, do you have clearance problems? Did any of you go back to stock height, or raise the car at all?
I just put these
in, and now I'm thinking I'm gonna have to raise it some, maybe with the 1LE springs!! Opinions/Suggestions?
[ January 21, 2002: Message edited by: JackZ28 ]</p>
Old Jan 21, 2002 | 03:00 PM
Ls1 346ci SS's Avatar
Default Re: For those with long tubes!!!
I have the Slp Longtubes with my car at the stock height and I have clearence issues on the right side because the header hangs a bit to low. everytime I go over a speed bump I break a sweat because I have to go over it so carefully. <img src="gr_sad.gif" border="0">
Old Jan 21, 2002 | 03:01 PM
SSG-Z28's Avatar
Wow, now imagine being dropped about 2 inches!
Old Jan 21, 2002 | 03:10 PM
Do you think at the track if you were to lift the tires off the ground at launch that you would hit the floor on the way down?
Old Jan 21, 2002 | 03:24 PM
SSG-Z28's Avatar
If I could, hell yes, but I can't!
Old Jan 21, 2002 | 03:26 PM
CamaroSSurge's Avatar
I also have the SLPs on stock ride height. Clearance issues on the pass header <img src="gr_sad.gif" border="0"> but its not too bad. Just drive carefully.
Old Jan 21, 2002 | 03:28 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
[quote]Originally posted by Ls1 346ci SS:
<strong>I have the Slp Longtubes with my car at the stock height and I have clearence issues on the right side because the header hangs a bit to low. everytime I go over a speed bump I break a sweat because I have to go over it so carefully. <img src="gr_sad.gif" border="0"> </strong><hr></blockquote>
When you say clearance issues, have you actually hit anything with them yet? I didn’t think that stock ride height cars were having any problems. None of the guys I know with them have this issue? Please advise...
Old Jan 21, 2002 | 03:29 PM
SSG-Z28's Avatar
That's just insane. I'm pretty certain that if I went back to stock height, I wouldn't have a problem! I just don't want to look like a 4X4 again, though! <img src="gr_sad.gif" border="0">
Old Jan 21, 2002 | 03:33 PM
well yes if i go slowly with both tires at the same time over a speed bump the right side header will scrape on the way down no matter how slow i come down. what I do to not let this happen is that just before I go over a speed bump i'll angel the car so that one tire(fronts) will go up on the speed bump at a time. I usually let the drivers side tire go up first and as it comes completely down the passenger side tire comes up and when I come back down slowly the pass header never scrapes the speed bump. hope this helps. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Jan 21, 2002 | 03:36 PM
SSG-Z28's Avatar
That's what I used to do with my cutout, but now, the problem is the driver's side, and I'd have to go across the oncoming lane to do that!!
Old Jan 21, 2002 | 03:37 PM
RPM WS6's Avatar
<strong>well yes if i go slowly with both tires at the same time over a speed bump the right side header will scrape on the way down no matter how slow i come down. what I do to not let this happen is that just before I go over a speed bump i'll angel the car so that one tire(fronts) will go up on the speed bump at a time. I usually let the drivers side tire go up first and as it comes completely down the passenger side tire comes up and when I come back down slowly the pass header never scrapes the speed bump. hope this helps. <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" /> </strong><hr></blockquote>
So it’s just a speed bump issue then? What I’m asking is, have you ever scraped them just like coming out of a steep drive ramp onto a higher street? Sorry if that doesn’t make sense. Have you ever scraped them anywhere except speed bumps?
Old Jan 21, 2002 | 03:48 PM
[quote]Originally posted by RPM WS6:
<strong>
have you ever scraped them just like coming out of a steep drive ramp onto a higher street? </strong><hr></blockquote>
the answer is a few times. like i said I have broken a sweat many times with these headers but the performance is awesome.
Old Jan 21, 2002 | 03:56 PM
ONYXSS's Avatar
My SLP's give me exactly 4" of clearance, which is plenty on a stock height car. I've never scraped them, on speed bumps or otherwise.
Definately not the best choice on a lowered car, though.
Old Jan 21, 2002 | 05:03 PM
BlackSuperSport's Avatar
I have FLP's on my lowered car & I've had no problems; they're awesome headers. I had SLP's on before but they hung down way too low & I scraped them a couple times so I got rid of them. On a lowered car FLP's all the way. <img src="gr_images/icons/wink.gif" border="0">
Old Jan 21, 2002 | 05:54 PM
Jackyl_30's Avatar
Speed bumps also can give me a problem too. I just go REAL slow and at an angle. I usually clear them like that with no problem.
Old Jan 21, 2002 | 07:10 PM
Navy David SS's Avatar
I was running the Sportline set-up. A little low. Change to Ground-controlled adjustable coil-over. I can adjust front and rear set-up in 10 minutes. I would never change out my headers. SLP are great.
David
Old Jan 21, 2002 | 07:30 PM
HalfMoon's Avatar
My headers have never scraped, my cats did once in a while when they were on the car.
