Could I use 1.8 roller rockers with this cam?
I have a GT2-3 camshaft from Lingenfelter--cam specs are 207/220 .578 .581
with a 112 LSA, would it be safe to run the 1.8 rockers or would i need flycut pistons, i dont know what my maximum lift can be, thanx in advance
Im not an expert by any means but im sure you can run 1.8 rockers with any cam it just depends on what springs you have. Im not 100% sure but with your lift with the 1.8 you will be close to .600 and maybe just over. I think you have to add 15-20% increase in lift with these rockers. Good luck
I have Comp 918's so i have that area covered, sorry< I guess i should've said that earlier--I haven't picked a rocker yet since i wasn't sure if i could even run the 1.8's with the lift of the cam cuz i know it'll be well over .600 lift. I have another question, but do 1.8s increase your valvetrain noise? I don't want it to sound like a sewing machine under the hood
Yes, they are on the edge. He really needs to know the installed height. If you get rid of the 918's, then you need to go with the Crane 833's with this setup. Don't go PRC or Patriots, I have heard from a couple of people the Crane 1.8's tickle one of the spring harmonics.
