Holley Intake = HEAT SOAK?
Josh
Tony
Has anybody considered building a "Intake Cooler"???
Like an intercooler that cools the intake itself.
Maybe some kind of case built onto the intake itself to fill with ice??
Is this good, bad, or just a no-no??
Makes sense to me, tell me why it won't work.
Taco
The heat soak issue is really in the top end of the engine, NOT the mainfold.
How much heat can be transferred to air when the engine is sucking 700-800cfm? The answer is very little. How many "manifolds of air" per minute go thru the engine? Probably more than you think. So there is little time for a rise in temp.
The reason the ice bag trick works is that the cooling quickly goes throught the manifold (not that much mass AND aluminum is an excellent conductor of heat/cold) and goes to the cylinders and water in the passages.
So I think that while you can cool an engine effectively by placing ice on the manifold, I don't think there is a great change in ambient air temp from an AL to a nylon 66.
The only way to know is to run insturmented tests <img src="gr_stretch.gif" border="0">
<strong>Josh, did the LT1/LT4 intakes have engine coolant circulating through them? If so, that would contribute to heat soak. These aluminum intakes will definitely hold more heat, and will probably reduce us to ice-bag mongers at the track. Might hurt my bracket racing
</strong><hr></blockquote>
LT1/LT4 intakes do not have coolant in them, but they do have hot oil under them.
Eric
doesn't spend enough time in the intake
to be heated by the heat transfer of metal
to liquid (fuel)Either cool fuel or Air
Air is tough to cool Fuel is heavier and
should hold temperature change longer
+ deg <img src="gr_images/icons/mad.gif" border="0"> - deg <img src="gr_grin.gif" border="0">
