Reverse torquer cam (the other side of the coin)
Still though those lifts are not for everyone and there are limits to everything.
After all why use a lift that goes beyond what a head can flow, like throwing stones at a wall.
For exemple:
232/228, .595/.588 108-1 LSA (108LSA/109 ICL)
So there it is for perusal and discussion.
That cam you recommend better not have the slightest bit of exh restriction, what so ever. Should lay down real quick after peak also. Seen stuff like that tried, even with open header picking up 25+ hp, still only make what good normal 228-232 stuff does
The graph above is proof. look at the trq curve from 3 K to 6.5K, that grind is doing exactly what it was designed to do;cam only,with minimum mods to support.
The graph above looks like a cliff at 64-6500 a hundred or two after peak?
It is all relative to what you want to do and your goals. Look at the trq output below the curve.
Yes it requires free flowing exhaust but that is a common trait amongst all reverse split.
The benefit is trq, what accelerates a car is trq.
This is a graph of the same car, with heads and 92/92 added.
Look at how it a carries after peak and the trq curve
Feedback by owner in this thread:
https://ls1tech.com/forums/generatio...-do-heads.html
To see is to believe
Predator spec'd the cam for me at the beginning, and I have been in contact with him from the start since I decided to add heads, Fast, etc.
He pretty much spec'd out what I wanted the car to do. I have ARP head studs, but everything else is untouched. That is why we stopped the pull at the RPM we did as I want to be safe.
But this setup showed no signs of dropping off and actually surprised me. Every pull made while tuning the car did this. I don't know how much more it would have carried past the rev limiter, but I was extremely happy.
And because of the small overlap, the car drives and idles smooth as can be. In fact, I am even thinking about putting the Z06 TI catback on. It would be one hell of a sleeper.
.050 VEs
9>IVO
49>IVC
45>EVO
9>EVC
108>ECL
18* Overlap
This with 2cc reliefs, 59cc heads, .040 gasket will net you 11.5:1 SCR and ~8.48 DCR
The reason i wouldn't go bigger than that is no point too much more lift on unported heads (not that big of a gain VS valvetrain instability)
I would run the lightest valvetrain you can put in with 918 springs.
Like (hollow valves, 918's, Tit. retainers, locks)
Again with LS6 intake, >>6300/6400 rpm peak, will carry and carry past that to neverland with a very flat peak. with proper gearing and suspension + hook this is a serious mid 10's setup (maybe less depending on car weight)
In cam specs you always play a tug of war. Reverse will have awsome trq below curve but that is traded by a few Hp on top. Basicaly they are intake biased cams. This is one of the reasons "El Toro" and derivatives are proving successfull, they dance on the line, play a bit on both sides if you will.
that comes from using dual lobes.
Vengeance is one shop playing that tune, they use combos of XE-R/XE (high lift), and their grinds are very successfull.
Still I would advise to check PTVC (so no surprises)
13* overlap, 6300 rpm peak minimum, needs LT/X/dual exhaust, and Ram air a plus.
That baby will need to breath.
