Reverse torquer cam (the other side of the coin)
Old Mar 9, 2010 | 11:50 AM
  #281
alans02z's Avatar
So If im reading this right, my Z06 would like the "El Toro" cam with lg super pros, no cats and borla stingers and be reasonable to drive with a proper tune? And by reasonable, I mean as a dd and not have surging or bucking issues in parking lots and traffic? Im also ready to order a cam. What specs do I need to have it ground?
Old Mar 9, 2010 | 02:14 PM
  #282
PREDATOR-Z's Avatar
Originally Posted by King Nothing
i'm looking at gettin the El Torro, a few questions first. how do i go about ordering it? lol since it's predator-z's spec i was gonna try to get a hold of him but last i checked his PM has been disabled so i'm wondering if TR has the cam on file somewhere or something and the second question is i though i read somewhere that the el torro cam 230/230 is a reverse split, i can't find where i read it and i'd like to see if i read the right thing. i know when reverse split is said people think of TR230/224 or TR236/230 so to me in my mind a 230/230 is a traditional split. hopefully predator or someone else can confirm or correct this
cam order sheet from TR
sticker on side of TR box assuming the cam doctor numbers
The "El Toro" is a 230/230 cam. Dual lobed XFI intake aned XER exhaust & When cut the XFI although advertised as 230 duration will come out as a 232 size, making it effectively a Reverse split cam.
Old Mar 9, 2010 | 02:37 PM
  #283
KILLERARMY's Avatar
Predator-Z, What's your email address or something? because i need you to spec a new cam for me.
Old Mar 9, 2010 | 02:42 PM
  #284
PREDATOR-Z's Avatar
marcsahib@yahoo.com
Old Mar 10, 2010 | 10:02 AM
  #285
GIGAPUNK's Avatar
It's been hinted that it might be worthwile to use a later IVC (even at the detriment of DCR) to gain top end power. It's obvious that a later IVC allows more filling time at higher rpms, what is not obvious is what rpm range equates to which IVC, and how this changes between a 370 and 427? Any insight to the non-obvious would be tramendously appreciated!
Old Mar 10, 2010 | 10:21 AM
  #286
GIGAPUNK's Avatar
from PAtrickG regarding a 346:
"I like to decide where I want my motor to make peak power first. 6000 rpm peak, I'll choose a 40 degree IVC. For a 6300 peak, I'll choose more like 45 degree IVC (ABDC at .050")."
Some say that the IVC/intended peak power range are related to the percentage of cylinder that are left to be filled when the intake valve closes. In which case comments like Patricks above would hold true for all displacemnts.
from Kevin Shasteen on hybridz:
"If you want a streetable engine with a relatively smooth idle in the 700-750 rpm range you will need a cam that offers an IVC that leaves atleast 75-80% cylinder volume after the IVC.
If you had a Crank Angle Chart you would see that 75-80% Cylinder Volume would require an IVC somewhere in the 61-70* (@ 0.006”) IVC ABDC range[with a 230 @ 0.050" xer lobe this would be about a 41 IVC ABDC]."
Old Mar 10, 2010 | 10:26 AM
  #287
PREDATOR-Z's Avatar
Keep in mind that there is more than just IVC. Other valve events have to be accounted for as well a supporting hardware such as intake.
Old Mar 10, 2010 | 10:39 AM
  #288
GIGAPUNK's Avatar
Obviously. I'm just trying to disect it down to one valve event at a time. And IVC seems like a good place to start. BTW your post count is INSANE! Thanx for all you do here!
Old Mar 18, 2010 | 06:41 AM
  #289
TXZ28LS1's Avatar
Check out this link!! another guy with the MTI X1 230/227 reverse split just put down 411/390!!! stock 243 heads and LS6 intake. imagine if he had some ported LS6 heads or even some TFS 215 and a fast 92/92..thats big power for such a small cam. to prove again that reverse splits do work...or should i say retard, band -aid cams..LoL!!
https://ls1tech.com/forums/multimedi...m-numbers.html
Old Mar 18, 2010 | 07:22 AM
  #290
pitbull14218's Avatar
Nice, im about to pick up a TR230 cam which is very similar to the X1 so i have heard.
Old Mar 18, 2010 | 01:05 PM
  #291
GrannySShifting's Avatar
Or it could have made more power with another cam. Weve made 430 with 228 duration cam on same stuff. Dont draw any conclusions from one guys dyno numbers. It doesnt mean anything.
Put a good head on it and FAST, and Id bet theres even a bigger difference
Old Apr 3, 2010 | 08:28 PM
  #292
Tweek's Avatar
So i recently finished swapping a 01ls1/t56 into my s10 and im already debating on what cam to go with. I know the ls1 is gonna stay cam only so im leaning toward the tr230. With just bolt ons the truck went 12.6 at 110 last week. I was wondering do you think the tr230 would be enough cam to get me into the 11s or should i go bigger. btw the truck is my daily driver.
Old Apr 3, 2010 | 09:06 PM
  #293
garygnu's Avatar
GM and the after market should be paying these guys for all they have contributed to the ls motor industry.they are the reason your ls motors kick *** !!!!!!
Old Apr 4, 2010 | 10:25 AM
  #294
All depends on the exhaust system etc.
Old Apr 4, 2010 | 11:06 AM
  #295
Tweek's Avatar
im running 1 3/4 mid length headers and 3in true duals with dynomax bullets dumped before the axle.
Old Apr 4, 2010 | 11:30 AM
  #296
SS#1230's Avatar
got any vids of the truck? that thing is sick!
Old Apr 4, 2010 | 02:19 PM
  #297
Tweek's Avatar
thanks man! no vids yet gotta find someone with a camera im not really into that kinda stuff. wish i woulda had one friday night i got to race an isf. proof of the kill would be awesome.
Old Apr 4, 2010 | 03:26 PM
  #298
King Nothing's Avatar
i was goin to go with that one mark but i'm going a different route down the road and i really don't want to do 2 cam swaps on the same engine in less than a year. the next LSX car will get the el torro cam or maybe something bigger spec'd by you
Old Apr 13, 2010 | 05:17 AM
  #299
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Up top. I am about to sticky this, but its not that huge of a deal yet.
Old Apr 13, 2010 | 05:58 AM
  #300
Squirts11's Avatar
I'm seriously considering giving this "reverse-split" type of cam a shot here in the next month or so.
Edit: Nevermind.
