All parts are on their way...new motor should be ready soon
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I placed the last order for shortblock parts today...I'll have everything I need for the short block by next weekend <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I have aquired a low mile (~20K miles) shortblock that had a melted ringland...machine shop said the bore was perfect so I'm using this as a base for the buildup <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
This is a LOW BUDGET shortblock...I could've spent tons of money on the bottom end but I wanted to see what I could do inexpensively.
3 things I didn't skimp on:
1) rod bolts
2) timing chain
3) oil pump
I'm replacing all 3 known LS1 problems with quality replacements. ARP Pro2000 rod bolts, Katech ported oil pump and SLP (*cough*Rollmaster*cough*) double timing chain with nitrated gears <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Other than that I bought a set of replacement GM pistons and rods from valvegod, Total Seal Piston rings from summit, Clevite 77 rod bearings from Summit, crane OEM replacement lifters from summit and Replacment main bearings from Katech. Due to the low mileage of the motor I'm not replacing cam bearings.
Top end of the motor will consist of GTP S2 5.3L heads milled .040-inches (2.02 intake) and a 232/232 .574/.574 112 camshaft <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
I'll build the bottom end next weekend and once the heads arrive (hopefully less than a month) I'll finish off the motor and install it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Exhaust will also be updated to Dynatech stepped headers, 3" collectors, 3" bullet mufflers off the collectors, dual 3" cutouts then a 3" y-pipe back to the borla via a 3" flowmaster y-collector I bought.
Hopefully it'll haul A$$ <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ June 21, 2002, 10:34 AM: Message edited by: Fireball ]</small>
1) rod bolts
2) timing chain
3) oil pump
Can't wait to see it in action. Why the small cam? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
cool looks good!! I would have went a little bigger on the cam <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I take it will be mostly NA? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Do you think you'll have enough gear? hahaha!
Cheers,
Chris
Cheers,
Chris
I'm not lining up behind you in the staging lanes. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> The way you launch something has to give. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> I'm sure its going to fly. Good luck.
Bruce
Bruce
Congrats! Could you post close up pics of the chains & plate markings when you get them? I'd like to see exactly what they are using.
Well, those $$$$ GTP stage 2 heads certainly arent "budget".
Sounds like a real nice engine when you are finished.
Good Luck'
Ron
Good Luck'
Ron
I can shift faster than you.
Sounds like a good setup Brian! Good luck getting together.
Ron, the heads are where the power is. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I don't think Brian minds paying a few extra bucks for some extra hp/tq. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> I do agree that a good clean up w/ stock valves would be considered "budget" though.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fireball:
<strong>This is a LOW BUDGET shortblock...</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Last time I checked a shortblock don't include heads <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
1 Post
FB, can you tell us what you dropped for $$ so far on just the parts you listed?
I'd just like to know for future reference when I do a rebuild.
Thanks!
Lee
Thanks!
Lee
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nine Ball:
<strong>Will this be the "biggest" hydraulic cam ever used in a street-driven 346ci LS1 motor?
Tony</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The first cam I put in my car way back when (3/00?) was a 232/232 .568/.568. With the 116lsa it was ground on, it didn't work too well. Probably would've kicked *** on a 112lsa...
PSJ had this same cam as well (this was the old GTP #4(?) cam).
well someone I know tried quite a bit bigger in a 346 but it didn't perform as well...but it did go low 11s <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
on a sidenote...my heads are DONE!!! woohoo...I gotta pull the heads off the car tonight to send Craig my double spring setup so he can do final assembly <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Fear...I'll look over all my receipts and get you a ballpark price maybe tomorrow
when are you expecting to get the heads in? I am excited to hear your results <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Chris
Chris
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong>when are you expecting to get the heads in?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Next week. But I still have shortblock assembly to do...should be up and running in 2 weeks or so <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Sounds like an awesome setup!! Good luck with it <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Try not to break anything... make sure people stand back a few hundred feet when you launch <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
well the short block is built <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
just waiting on heads...shipped Craig my double spring hardware via Priority US mail Friday and he hasn't received it as of yet
<img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> US Postal service
so I dunno...if he don't get them by Friday..I guess I'll have to buy new ones to get the heads finished and the motor buttoned up <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
This sucks <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" />
Oh..the block I took out was in SAD SAD shape haha <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
