How many of you 346 ci heads/cam cars have busted an M6 tranny or blown an engine?
LS1Tech Administrator
Received 1,688 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Many guys have busted auto trannies with a stock motor...maybe you are referring to a M6? Just about every H/C auto I know of has blown the stock trans in short order. Granted, the lighter the car the longer they will usually last. Point is, if you want H/C in a auto car, you need some tranny work if you want it to last. Even then you still might have issues if you let the temps climb too high...
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RPM WS6:
<strong>Many guys have busted auto trannies with a stock motor...maybe you are referring to a M6? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am referring to an M6 car more than anything.... I was also thinking of stripping some weight off soon to help keep my tranny and rear end from biting the dust. I was going to do the following:
K member/A Arms= 45lbs
Lightweight carpet= 30 lbs
Lightweight hood= 20 lbs
Racing seats= 40lbs or so??
Polycarbonate Windows= 66 lbs (but very pricey)
So about 200lbs of weight to shave and to keep the car looking very stock. Unfortunately, the cost of doing all these things is goind to be in the area of $3000 <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
It hasn't helped much that I've added about 50lbs in stereo, and about 50lbs between my 12 bolt and suspension <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I've tried to counteract that weight gain by removing my spare tire/jack, front sway bar, using eradispeed rotors, aluminum flywheel, and carbon fiber driveshaft, all of which have shaved back about 80-85lbs.
<small>[ July 24, 2002, 01:33 PM: Message edited by: verbs ]</small>
Our M6 trannies are not idiot proof. I'm a living testimony to that.
<img src="http://www.akmcables.com/Second.jpg" alt=" - " />
I have a cam and headers, 12-bolt, Cartek, Denny's, stock heads. That's second gear, and I think I did this during my burnout (burnout with linelock / ET Streets in second). Rest of the tranny is fine, tho. Hopefully I'll be putting it back together later this week.
-Andrew
-Andrew
1 Post
I can say I've done both, tore up my tranny and destroyed the motor on NOS. But at least I had a 540 rwhp car for a day. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by verbs:
<strong>Just curious as to who with just heads/cam and stock displacement have busted a tranny or blown an engine or both???
What do you think caused it to happen?? How many times has it happened? How'd you fix the problem??
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My stock cid motor lasted two years with me beating the living hell out of it every chance I got. The shortblock was all stock '98 with the exception of the .005" over Wiseco forged pistons.
I can say with 99.5% certainty that my failure was due to the stock rods/rod bolts. They just don't seem to like ~7000 rpm.
I'm fixing the problem by installing an ARE 382 all-bore motor <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
2 motors and 4 trannys
1. Nitrous
2. Rod Bolt let go on the secound motor.
1. Nitrous
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by wicked 98z:
<strong>2 motors and 4 trannys
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
I better start looking for horseshoes and 4 leaf clovers <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
stock motor, lid, exhaust, stock clutch... 3 trannies go bye bye! The first one died because of the stock shifter, kept mising 3rd gear and it bent the shift fork so 5th disapeered, then after that the rebuilder screwed up twice and it got stuck in 6th twice after racing. I don't think any of these were power related, but the stock clutch has since died <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I want to make sure I don't go through the same pitfalls as some of you who have had problems. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
<small>[ July 24, 2002, 01:12 PM: Message edited by: verbs ]</small>
Come on, there's gotta be way more of you than this!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Maybe everyone's hiding their heads in shame <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GeorgeC:
<strong>Maybe everyone's hiding their heads in shame <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think you're right <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I had over 800 passes on my car BEFORE my H/C package. Im a little nervous now. Just turned 50k. Other than several stock clutch replacements, no tranny problems thus far. I have a ripper shifter, I dont flat shift, but I do speed shift. If anything in my drive train lets goI cant bitch at all!!!Im certainly not saying it is the only oil thats any good, but all Ive ever used is Mobil 1 every 3k.BTW, Im puttig in a 12 bolt this weekend cause the rear is screaming like a banchee!!
Sorry to say but the tranny has held tight and the motor has beaten beaten senseless for 51k miles. Came to a light last night after rompin on it and the got a really nice sound of a bearing spinning. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Not for certain that's the problem since we haven't ripped it apart yet but I'd bet it is. I'm guessing this car has 3000+++ 1/4 miles passes on it, atleast 1000 6000rpm launches so I'm sure that didn't help any either.
Time to pull it apart..I think George C summed it up best because this is exactly what happened to me.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">My stock cid motor lasted two years with me beating the living hell out of it every chance I got. The shortblock was all stock '98 with the exception of the .005" over Wiseco forged pistons.
I can say with 99.5% certainty that my failure was due to the stock rods/rod bolts. They just don't seem to like ~7000 rpm.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Mine went when I had an injector lock on #7.. melted part of the piston to the block! The ringlands were gone as well.
Went with JE pistons, Manley rods, and total seal rings.
Car was perfect before then, and has been for the 600+ miles on the new block so far ( with exception to a bad head gasket )
I finaly blew an M-6 tranny last December.I think it had something to do with powershifting and a slave clyinder problem at the time.If you want to save your tranny,don`t race.
I just had my tranny rebuilt (synchros). I think it was because I missed some 3rd gear shifts before I had my ripper. I had my slave cylinder replaced also because it was going south. That could also be one reason my synchros went bad.
lid, FTRA, MAC's, orp, ripper.
I have broken 1 tranny, but I am currently working on my 2nd <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I have lost one motor, but that was due to Nitrous use on a very worn out 60K plus stock shortblock.
All is well now tho <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
No problems here, car has 62K miles on it, had the H/C on the car for about 3k. My tranny is the only drivetrain item that I haven't had trouble with thank god. The CARTEK HYDRAULICS BLOW and are used, so I had to replace them with brand new revised GM hydraulics, and I just shattered 3 teeth off the ring gear in my rear.
Am on 2nd Engine ala Oil Pump failure.
Am on 3rd tranny (rebuilds).
Tranny probs were due to bad lower shifter mechanism on delivery from factory. Took 3rd rebuild 'til they found it. My M6 sucked until they found and replaced that. Started on delivery of car w/7 miles. Nightmare. All good now.
