MS4 110 Lsa First start up
How much more Lehman can I get by saying that lifts have very, very, very little to do with PTV at the durations we are running. (you can literally say nothing to do)
Look it is simple, at TDC valves are closed (lowest lift point), at or close to BDC, valves are open to their maximum (piston is in the bottom), max lift.
So the danger lies when the piston comes back up close to TDC. If at that time the valve is still opened too much, whack, Mr. piston meets Miss valve.
The time action of the valve opening or closing is dictated by the Durations and the Valve Events of the cam. Valve Events are dictated by Duration, LSA and ICL. Lifts are not involved at all.
Exemple: a 224/224 .563/.563 112+4 LSA (TR224), has the same VEs than 224/224 .581/.581 112+4 (Comp XE-R) and the same VEs as 224/224 .636/.636 112+4 (Comp LSK).
If the TR 224 clears a certain head so will the others even though you can see the lift difference. THEY ALL HAVE THE SAME VEs
Now change the VEs (which means a different LSA/ICL) and at a certain level, you can find yourself with a cam that doesn't fit even with same Durations.
I really can't explain simpler than that.
Go to the second animation... perfect example of how overlap and lsa affect PTV. Max lift happens when the piston is plenty far away fromt the valve even at .900 lift or more. Lift has nothing to do with PTV. It is duration and or overlap. i.e. LSA/ICL.
One could argue ramp rate and lobe design could affect PTV but nothing like the overlap, LSA, and ICL does.
http://www.gmhightechperformance.com...ls1_dyno_tech/
it doesn't add up...
Id like to personally call out anyone who has had this cam.. and actually had the ptv clearance issues..
Ive heard little to no issues regarding TSP and their product..
Please do not insult Predator... He went out of his way to enlighten us in his knowledge.
Today, the base tune goes in.. Ill get some more video's up
Also Lift has nothing to do with PTV clearance to the people who keep arguing it
As i said, it is your motors, not mine.
Ask TSP what is the clearance margin on intake and exhaust. If it is at or more than .080 intake or .100 exhaust, I will eat my cap (with a bit of Ketchup).
And just so you know what to ask just say :
" Mr. Zack, please tell me what are the PTV clearance margins on a MS4 with a 110 LSA"
So just so you guys understand what I'm saying. MS4 on a 110 LSA is very tight on PTV and danger of contact is imminent. Install at your own risk.
Oh and LIFT has no (as in negligeable) effect on PTV at the size of cams we run in our LSX motors.
and tuffass, you are judging me after posting in this:
https://ls1tech.com/forums/generation-iii-internal-engine/671672-installing-cam-dot-dot.html
Get real
Some poeple really need to grow up, at your age i would get pissed, now i find all this ammusing
I just hope some readers can sift through and take the warning seriously. Last edited by PREDATOR-Z; Mar 9, 2007 at 07:53 AM.
You guys seriously, who or what business is going to post every possible outcome or combo.
Second, why would they post up problems when all it would do is turn away potential buyers.
There are several threads with good and bad on several shops.
This isn’t TSP bashing, I'm just providing facts. Facts that these members asked for.
Here are Several Threads that WERE NOT POSTED ON TSP's SITE! With KNOWN ISSUES. From fake flow numbers, to a MS3 lobe breaking, to a "Bad Batch" of heads/ milling heads so low to gain better flow.
https://ls1tech.com/forums/showthrea...ight=Broke+MS3
https://ls1tech.com/forums/showthrea...hlight=TSP+LS6
https://ls1tech.com/forums/generation-iii-internal-engine/351379-if-you-bought-prc-heads-considering-check-out.html
I have pics of the heads breaking in places you wouldnt believe.
Some members other members who’s cars were destroyed because of this.
Joe - T56rebuilds.com Sponsor
2 different Moderators
Several members - use the search
TSP did make good and helping out these members in some if not all cases. You guys can read some of the threads listed and make up your own mind.
Honestly thou I don’t read or hear about many cams breaking at the lobe, or bad batches of heads. Fake flow numbers actually comes up more often to none cause it pulls in people in belief of getting those flow numbers for their cars. TSP has their good customers with lots of happy people. These are some of the bad that have been known and people dont or didnt know about. Im sure there are plenty of people that can voche for the guys up at TSP.
Hope my copy of the TPS report helps you guys out to shead some light in some areas.
Better to be safe then to be sorry, always be safe.
KrisXpc: Your car sounds awsome, serious take care and I wish ya the best.
Edit: Seeing how I also needed information about the cam. And several replies about not advising the 110 lsa comments in this thread. I sent pms to each person and asked why. NOT 1 response from anyone as to why. Seeing how they were told no, I would normally tend to ask why. I too called TSP 5 times today and got nothing but a busy signal. Ill try again tomorrow and get a definite answer.
ms4
prc stage 1 ls6
Heres what I do know, with their 5.3 heads they recommend fly cutting the pistons with their ms4 cams on any lsa. With their LS6 heads the cc is smaller then the LS1 heads. 67cc vs 64.5cc hence the p.rod length/gasket/ heads matter. More factors come into play then just saying what will and wont work. So in short without you guys saying why, these are worthless replies.
-N
https://ls1tech.com/forums/showthread.php?t=671672
Get real
I just hope some readers can sift through and take the warning seriously.I agree its anoying to be insulted for knowledge your putting out, But calling tufass out wasn't really needed man.
We all had to learn at some point in time.. for most of us budget builders the only way we can learn is to ask.
Im still giving TSP a chance here to get in touch with me. Ive heard nothing but top notch customer service. We all get a little busy.
Either way. I Want to see TSP put this to rest. Even if its going to sting..
I feel the same way lol
