View Poll Results: T-Rex or MS4
T-Rex
87
36.86%
MS4
122
51.69%
Custom (explain)
27
11.44%
Voters: 236. You may not vote on this poll
T-Rex or MS4
Old Mar 14, 2007 | 02:03 AM
kaos_'s Avatar
Originally Posted by orangeapeel
You wouldn't have all that lowend power you are describing with a Trex. It is a top end cam. That car would have to have 4.30's+ to even be that nimble from a dead stop unless he power braked out of the hole at like 3.5k.
4.10s, rearend, suspension and some et streets (what the car has) will grab and launch pretty hard off an idle roll in traffic if you just floor it. even with a humbler cam setup.
Old Mar 15, 2007 | 12:45 PM
Vette1171's Avatar
I went MS4 because it was a little less aggressive...but just a little...
Old Mar 15, 2007 | 02:21 PM
monicaz28's Avatar
Both are great cams, but looking at your set up, the Ms4 would be the better choice IMO.
Old Mar 15, 2007 | 03:16 PM
santiago's Avatar
i jus bring it up to 3.5 k and dump it thats all the lowend i need
Old Mar 15, 2007 | 04:08 PM
N4cer's Avatar
Seems like the MS4 and Trex are pretty close. But really I haven't noticed the MS4 having any more ***** down low than the Trex. At least from reading on here. I know I had 2 friends hit the dyno this past weekend, and even the MS3 had less ***** down low than the other one's Trex.
Just read and see what makes the power. Don't read the crap posted by shops, or by the mindless lemmings that wouldn't know the difference if a cam was stuck up their rectum. Look at the fastest cars. Easy enough.
Old Mar 15, 2007 | 04:27 PM
monicaz28's Avatar
Look at both with those heads. That's the key in this situation.
We have a T-Rex in one car and an Ms4 in the other car and I can tell you that as far as power (both stock heads), they are very very close.
Old Mar 15, 2007 | 05:45 PM
N4cer's Avatar
yeah. i agree. the key to gathering the info from here is to look at the source.
Old Mar 15, 2007 | 07:40 PM
multiplicityZ's Avatar
its funny in a way, a while back everyone was for the trex, now its the MS4. both seem to be great cams, but a lot of the people with the MS4 haven't gotten down the track yet. before i make any decisions i wanna see the time slips. but i'd probably go with a custom cam either way...
Old Mar 16, 2007 | 12:03 AM
import slayer's Avatar
T-REX FTW!!!!!!
Old Mar 16, 2007 | 12:05 AM
MS4
Old Mar 16, 2007 | 07:20 AM
CodeRed2000SS's Avatar
ms4, got my vote
Old Mar 16, 2007 | 07:29 PM
  #32
Phynix's Avatar
Who told you that? It is a bigger ring and a butch pinion. 9" would be the stronger, spooled or not.
A tech at moser actually did, and I have seen both rear ends on the same turbo car, no spool on either, but btoh built as strong as possible without spooling the rear, 9in blew in an auto car, 12 bolt is still holding up over a year later
Old Mar 16, 2007 | 08:16 PM
  #33
N4cer's Avatar
That means nothing. Could be setup on that.
Old Mar 16, 2007 | 10:22 PM
  #34
RrCoX22's Avatar
the thing is we all know the trex is proven... just a matter of some time to pass for the ms4 results to show and compare
Old Mar 17, 2007 | 01:56 PM
  #35
kaos_'s Avatar
werd. let's see some results. i'm interested in cam only 1/4 times, personally.
Old Mar 20, 2007 | 09:29 PM
  #36
tillery's Avatar
how bout a vindicator cam from vengance, I have a MS3-and looking to change to this
Old Mar 25, 2007 | 12:52 PM
  #37
ws.6kid's Avatar
I'm still looking for a MS4 to run... Plan to get it on video and settle this once and for all.
Old Mar 25, 2007 | 02:11 PM
  #38
Chiet_SS's Avatar
I vote for the "S" cam from HPE I dont like the MS4 as it doesnt start making real power till the top end. I have seen it in a car and a 6.0 truck and neither of them made much power till 4K, but it pulled like a bat out of hell after that.
I prefer the "S" cam as it makes great power all the way throught the power band!
Old Mar 25, 2007 | 03:29 PM
  #39
dpw41285's Avatar
trex but i would go custom grind thats what i did. pm me if you want someone to spec you a cam and not charge you for it!!
Old Mar 26, 2007 | 12:02 AM
  #40
Phynix's Avatar
my ms4 is making plenty of power before 4k, its not just about the cam and the rest of your setup, its all about the tuner in fact its mostly about the tuner, you can have the best setup and run low 400s in rwhp
