LS6 vs. 6.0 liter truck heads -- flow numbers inside
I can shift faster than you.
A pair of 6.0l heads showed up today at the shop. It was the first time we had a chance to look at them compared to the LS1/LS6 head.
There has been alot of talk on how the heads compare to the LS6 castings. The intake and exhaust ports are VERY similar to those of the LS6 head, but the combustion chamber is shaped like a LS1 casting (but only larger).
I didn't have time to CC the intake/exhaust runners or the combustion chambers on them. Hopefully, I might have some time tomorrow to do that.
Here is a graph on how the 6.0l heads compared to LS6 heads (stock vs stock):
LS6 vs 6.0l
6.0 flow numbers
LS6 flow numbers
As you can see, the 6.0l heads have awesome low/mid-lift numbers, while the LS6 heads shine past .500 lift. Patrick G had mentioned this awhile back after Judson (SAM) had worked on a few sets in Houston. The 6.0l heads would make a great street cylinder head with some minor porting, as long as you can get the compression back to around stock with some milling. The LS6 heads look like a great choice for those with a huge lift solid (or hydraulic) roller.
It will be interesting to see what happens after some porting. The heads are shipping out to Craig @ GTP tomorrow so he can work his magic on them. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Jason
<small>[ September 18, 2002, 10:36 PM: Message edited by: Jason99T/A ]</small>
LS6 vs 6.0l
6.0 flow numbers
LS6 flow numbers
Jason
Re: LS6 vs. 6.0 liter truck heads -- flow numbers inside
Thats a great comparison.. I know for sure I am getting 6.0L heads on.. I have to decide if I want to drop the compression for boost or mill the head out of them for NA..
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by VINCE:
<strong>Thats a great comparison.. I know for sure I am getting 6.0L heads on.. I have to decide if I want to drop the compression for boost or mill the head out of them for NA..</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Time to order some heads Vince. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I'm missing the difference between these... Is it the Flow pressure that is important because that is the only real difference I see. The corr CFM seems real simular.
<small>[ September 19, 2002, 09:36 PM: Message edited by: h53speed ]</small>
Adkoonerstrator
Jason
How do the 6.0L heads flow on a 4" bore. I'm just wondering if the combustion chamber design for the 6.0L is a disadvantage being flowed on a bore it wasn't meant for.(even though its just a little)
Maybe you could flow both heads on a 4" bore to see if the difference between the two is less. I still think the LS6 will outflow it but, maybe the 6.0L will close up the gap some.
Good work! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John
John
John, I didn't flow them on a 4.0" bore because these heads are going a stock bore motor. I would be interesting to see how they do though. I'll see what I can do tomorrow.
Jason
Jason
Adkoonerstrator
Well, if you get the chance. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> If not I guess I understand. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Thanks
John
Thanks
John
very good choice sending them to Craig as he does shine when it comes to the porting, You guy's have to see my new gutted ls6 Holley intake he did for me...These are going to sell like hot cakes!!!!!!!!!! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
That is great info. You wouldn't have that same info for stock LS1 heads and 5.3 heads would you? I'm sure that there are many of us that would like to see how the 5.3 and LS1 heads compare in stock form.
Yeeeeahhhhh.....
We need a massie head shootout. Every stock Ls1 based head and then a ported version of each. Maybe even on stock bores and then on bigger bores also.
I have this over in my thread, but I stole your numbers, and put them into the spreadsheet. If you have any more sheets, please post them....
I would also like to see as shootout on the heads.
<img src="http://www.z06vette.com/gallery/data/1067headflow4.jpg" alt=" - " />
I cant wait to see what GTP can do with the 6.0L heads.. Perfect to help with big cams low end loss and should build up quite nicely..
J-Rod, that flow sheet comparison is really not an accurate way to compare two heads at all and is misleading. Different flow benches etc and not to mention flow numbers do not tell the whole story.
